Engine swap - Road Glide Forums
post #1 of 4 (permalink) Old 06-19-2013, 11:45 PM Thread Starter
Engine swap
I need ur help guys! I have 2006 RG with 95 cubic motor and I was wondering if I could put 2011steet glide 103 motor in it? Do the bolt right up? The reason iam asking is I got killer price on the 103 with stage 4 kit, and my old 95 stage two is getting pretty miled up any info would be good info thanks
Wilson88 is offline
post #2 of 4 (permalink) Old 06-19-2013, 11:57 PM
spokanebagfan's Avatar
No it will not work with the tranny, but some have said there is a way to change it so it will fit or buy a six speed tranny with it
spokanebagfan is offline
post #3 of 4 (permalink) Old 06-20-2013, 02:33 AM
RoadGlideRider's Avatar
The motor will fit the frame, but the transmission will not fit the motor.
If you are able to get a later transmission with it, it will work.
You must make sure the electrical will connect too.
RoadGlideRider is offline
post #4 of 4 (permalink) Old 06-20-2013, 10:29 AM
torqu's Avatar
Oil passages are totally different . Older twin cams had external lines. Newer ones are internal.
torqu is offline
Check engine light after bar swap BBecker Controls & Handlebars 13 10-09-2015 07:16 AM
Engine Swap Advise BDMastiff Engine Related 6 12-29-2014 06:08 AM
Engine and tranny swap burph Engine Related 4 01-16-2013 11:16 PM
engine swap dbizzle75 Engine Related 3 09-17-2012 07:22 PM
Engine swap. Roadie *General Road Glide Discussions/Pictures 21 04-28-2010 08:20 PM
