Need y'all's opinion. - Road Glide Forums
post #1 of 26 (permalink) Old 06-23-2013, 09:35 PM Thread Starter
DC-3Mek's Avatar
Did an inspection inside the crankcase. Found these three issues. The chipped gear tooth I don't think is a big deal. I'm going to blend it smooth and so should be ok for a while.
The chain tensioner is no biggie either, but what do y'all think about the clutch hub eating into the case a little. I'd guesstimate about .010".
I'm lookin to get another 6 thousand miles or so out of it. I'll change it after Sharkweek. I overhauled the starter and it was good to go. The terminals were nasty with corrosion so I cleaned them shiny and put Stabilitant 22 on them so that should take care of the starter drag issue.
I'm mainly concerned about doing too much harm to the tranny with a clutch or main bearing going soft. ImageUploadedByMO Free1372037589.078072.jpgImageUploadedByMO Free1372037605.799174.jpg
Ride more.......post less........................~
DC-3Mek is offline
post #2 of 26 (permalink) Old 06-23-2013, 09:36 PM Thread Starter
DC-3Mek's Avatar
DC-3Mek is offline
post #3 of 26 (permalink) Old 06-23-2013, 10:28 PM
Hullhorr's Avatar
I have the same gouge in my inner primary wall. Did you inspect the inner primary bearing and race? Based on the wear on your chain tensioner I would figure the primary bearing and race are probably shot. 2 people had primary bearings go out last year on the way to Shark Week.
Pull the clutch hub and take a look. If there is any wear I would replace it before you leave for shark week. I would also recommend replacing the stock chain tensioner with the Hayden. If money is no object replace the stock compensator for the SE one too.
Based on that gouge I think it's safe to assume either the inner primary bearing or the trans main bearing are bad, maybe both.
2009 FLTR MOP
Hullhorr is offline
post #4 of 26 (permalink) Old 06-23-2013, 10:32 PM Thread Starter
DC-3Mek's Avatar
The bike has 67,000 miles on it, I'm somewhat easy on it. I may have to be till I get back from SWIII....for sure!
I haven't notice any noise, it has been making some fuzz, but I think that's coming from the rollers on the chain due to the gear tooth. I found the chips just before 60k mileage so it's got roughly 7 k on it since the fuzz.
I'm going to clean the case out real well and ride it and see.....I just don't have the money to go through it like it should be until I get back. If worse comes to worse, that'd mean not going to SWIII........
DC-3Mek is offline
post #5 of 26 (permalink) Old 06-24-2013, 12:35 AM Thread Starter
DC-3Mek's Avatar
Hulhorr, I know you did an awesome job documenting your rebuild, would you possibly have the particulars for the kit, tools, prices? etc.???
Girlfriend says "Make the bike right".....good woman! And I'm not crazy about worrying whether it's gonna make it or not. I don't want to risk it with her on the bike and the both of us going to SWIII
Any input you could give me would help insure I can make it there! Thanks in advance....and I'll be doing my homework on this end.....such as which pullers I need as opposed to what I or work has....being an aircraft mechanic has it's advantages!!!!
DC-3Mek is offline
post #6 of 26 (permalink) Old 06-24-2013, 02:22 PM
Hullhorr's Avatar
I would just be concerned with the inner primary bearing and race for now. Once you take the clutch hub, compensator, and the inner primary case off you can grab ahold of the mainshaft coming out of the transmission and see if you have any movement. If the movement is minimal I wouldn't worry about the trans before your trip if it's not making any noises.
I could have probably held off a while before doing my trans bearings, but I was chasing noises.
Here is a link to two places for the inner primary race removal and install tool. Georges garage is one and MBSmfg. is the other. MBS sells there stuff on ebay and is a little less expensive. Georges Garage is where I bought the majority of my transmission tools. You will need a shop press to remove and install the new bearing in the rear primary case cover.
You can have my original chain tensioner if you want. It was still in great shape, but I highly recommend you go with the Hayden tensioner. PM me your address if you decide you want my old one and I'll send it to you.
http://georges-garage.com/trans_06_up.htm
http://www.ebay.com/itm/Harley-Big-T...09cedd&vxp=mtr
2009 FLTR MOP
Hullhorr is offline
post #7 of 26 (permalink) Old 06-24-2013, 02:37 PM
Hullhorr's Avatar
When you check the mainshaft for any movement, you will need to loosen the rear axle nut to create some slack in the belt. The parts you will need for the primary bearing & race are:
34091-08 Race
9231 Bearing
12052A Seal
60678-85 Retaining Ring
34934-06 Gasket
34901-07 Gasket
786A Sealing bolts (5)
2009 FLTR MOP
Hullhorr is offline
post #8 of 26 (permalink) Old 06-24-2013, 02:41 PM Thread Starter
DC-3Mek's Avatar
LOL!!! I just PM'ed you! I went straight to my CP and did it, and you were here posting!
I'll do all the above, I need to go the minimal route right now, but if it needs it, it's definitely getting chunked!
I appreciate the offer on the tensioner, but I got the Hayden on the way already, should be here Thursday.
As I said in the PM, I'm going to pull the clutch and check measurement/movement on the shaft. Don't have any noise that I'm chasing, so that's good.
Right now I'm thinking like you, primary and/or clutch bearing. But I'm gonna throw in the SE comp. and a new drive chain and sprocket since the old sprocket has the chip in it and the chain rollers show evidence of pitting and damage. I'd like to changed the clutch hub, and probably should, but just can't swing too much money right now. I'll make a final determination soon. Just trying to balance need versus SWIII money/time......
DC-3Mek is offline
post #9 of 26 (permalink) Old 06-24-2013, 02:42 PM
Rowdy's Avatar
Glad to hear the GF talked you in to fixin your ride. It would suck the fun right out of a road trip to have your bike crap out on you. Not to mention wondering about it the whole time. Good luck with the repairs.
Rowdy
Rowdy is offline
post #10 of 26 (permalink) Old 06-24-2013, 02:44 PM Thread Starter
DC-3Mek's Avatar
34091-08 Race
9231 Bearing
12052A Seal
34934-06 Gasket
34901-07 Gasket
EXCELLENT THANK YOU!!! I really appreciate your help! I'm battling a time issue...at least I don't want to run into a time issue....IT'S ONE MONTH TO SWIII LEAVE DATE!!!!
DC-3Mek is offline
Need Opinion Kps657 Seating: seats, backrests 7 10-13-2016 07:56 PM
ENGINE BUILDERS: I Need an Opinion on High Capacity Oil Pan for 120" RGKen Engine Related 10 05-29-2015 07:46 AM
Need an opinion! maurij1 Wheels and Tires 8 09-16-2013 01:08 PM
Need opinion on seats. Lower back pain Bama_hdrider83 Seating: seats, backrests 36 12-17-2012 09:54 AM
Need opinion on inner fairing paint color JuicedHD Paint & Bodywork Section 25 08-31-2012 10:37 PM
