???? About swapin out cranks - Road Glide Forums
post #1 of 9 (permalink) Old 07-01-2013, 11:45 AM Thread Starter
I got some????? About swapping out cranks. I have a '06 88A and I'm lookin at swapin out the crank with on from a 07-newer 96A. I'm goin to use some SE 110 heads and jugs from Revelation Performance to make a 124. What all do I need to change out to run the 07-new crank?
Mohawk is offline
post #2 of 9 (permalink) Old 07-01-2013, 12:10 PM
Hullhorr's Avatar
I don't know if a crank from a 96" will work in a 88" bike or not, but your going to need to send the bottom end out to have everything done anyway if your going to bump up to a 124". With a 124" you will need to bore the cases, and have the crank done up to handle that kind of horsepower and torque, and the vast majority of people do not have the equiment or know how to do what will need to be done. Darkhorse, Drago's, or Hillside would be my recommendation the latter 2 being forum sponsors here.
2009 FLTR MOP
Hullhorr is offline
post #3 of 9 (permalink) Old 07-01-2013, 12:14 PM
The stroke on a 96" crank is longer than that of an 88".
HogPro is offline
post #4 of 9 (permalink) Old 07-01-2013, 12:42 PM
May need to be changing out that bong water first.
reds4 is offline
post #5 of 9 (permalink) Old 07-01-2013, 01:38 PM
tdkkart's Avatar
Off the top of my head, I think in order to get to 124" you need a longer stroke crank than a 96" motor had in it. AND, if I was building anything that required a longer crank I sure wouldn't be using OEM wheels or rods. If you're gonna do it, do it $$right$$.
tdkkart is offline
post #6 of 9 (permalink) Old 07-01-2013, 01:50 PM
caboverbob's Avatar
Me agrees !
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
caboverbob is offline
post #7 of 9 (permalink) Old 07-01-2013, 06:26 PM
prodrag1320
Guest
Posts: n/a
a 96" stroke is 4.375",a 124" will need a 4.625".you will also need all late primary parts too as the 88" compensator is different (as is the whole spkt shaft on the later f/wheels)why not just get a S&S 4.625 F/W set (for a 99-06 motor) & S&S 4.125 cylinder/piston kit?? we do alot of 124" motors and the way your thinking isnt the best way to go about it (cases will need to be machined also no matter what way you go)
post #8 of 9 (permalink) Old 07-01-2013, 11:43 PM Thread Starter
I'm using Revelation Performance jugs that are 4.250 on the bore so the 4.375 stroke will make 124ci. As for the S&S crank it's not welded. I'm gonna have the crank trued welded and balanced with H-beam rods so it will make for a stronger unit then a S&S unit. I just wasn't sure about the primary parts.
Mohawk is offline
post #9 of 9 (permalink) Old 07-04-2013, 03:44 PM
FLTR2008Trike's Avatar
Your gonna have to do some math to figure your primary drive ratio. The 07 and newer flywheel assemblies use a different engine sprocket both for shaft fitment and # teeth and # of teeth for the clutch sprocket . Your 88" stock primary ratio is 1.54 for the 5 speed trans compared to the newer Harley primary ratio which is 1.35 with the 6 speed
Down at the bottom they have the charts with the ratios for both 5 speed engines and 6 speed engines
http://www.hotbikeweb.com/tech/0904_...n/viewall.html
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
Peeling out on a dead horse……backing up……and peeling out on it again – Sorry 21 Qs skipper Wheels and Tires 13 09-23-2013 03:36 PM
check out these guys mslater7412 Videos 2 08-14-2013 09:24 PM
And I thought we had all the cranks in England,apparently you've got some too Bigtrev8xl General Off-Topic Discussions 10 03-31-2013 07:46 PM
Cranks TAD2007 Engine Related 3 11-09-2012 07:03 PM
Last springs out west trip DRAFT1 Videos 6 01-26-2010 07:30 PM
