Dropping the clutch ???? - Road Glide Forums
post #1 of 16 (permalink) Old 07-02-2013, 12:58 AM Thread Starter
h-donut's Avatar
thinking about lowering the clutch plate when I change the fluids
anyone have any favorite setups? 3/4 turn 1 1/2 turn
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #2 of 16 (permalink) Old 07-02-2013, 04:20 AM
Bigtrev8xl's Avatar
Not sure what you mean by "thinking about lowering the clutch plate", I do mine as in the video, 1/2 turn clearance
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #3 of 16 (permalink) Old 07-02-2013, 08:55 AM
Roadie09's Avatar
The adjustment is a fine line. Back it off more than 1/2 turn and it is a bitch to get in gear or push around with the clutch pulled in (clutch plates drag). Adjust less than 1/2 turn and clutch pack can slip under heavy load once it gets to operating temperature.
You are not going to hurt anything by experimenting, but unless you change the spring, or plates, or install some other device there is not much to improve in stock clutch area.
Roadie09 is offline
post #4 of 16 (permalink) Old 07-02-2013, 09:07 AM
tdkkart's Avatar
5/8 turn works good for me.
tdkkart is offline
post #5 of 16 (permalink) Old 07-02-2013, 11:09 AM
Don't go 1 1/2 turns. The book say to go 1/2 to 1 full turn. I go 1/2 of a turn with good results.
post #6 of 16 (permalink) Old 07-02-2013, 02:29 PM Thread Starter
h-donut's Avatar
the feedback is appreciated
h-donut is offline
post #7 of 16 (permalink) Old 07-02-2013, 04:50 PM
If the clutch feels good and there is no slippage then there is no real need to adjust it. Everytime I adjusted my clutch it didn't need adjustment and I was just wasting my time. I do check the clutch adjustment after any work that has been done under warranty that is done inside the primary, one HD dealer that did some work to my bike had the clutch out of adjustment and they did not put in enough fluid, that was the only time I had to adjust the clutch.
post #8 of 16 (permalink) Old 07-02-2013, 05:45 PM Thread Starter
h-donut's Avatar
I know, this sort of topic is boring, I think I'll try 1/2 first,
I'm not making bank at the tT or anything, just sightseeing
but my feeling was, as with most things, there would be some independent though on the subject and that is what matters
good info
h-donut is offline
post #9 of 16 (permalink) Old 07-03-2013, 03:23 PM
I have been adjusting my clutch 1/2 turn and do get slippage when riding 2up. Which way do I adjust to correct the slippage, 5/8 or 3/8 turn?
ksarauer is offline
post #10 of 16 (permalink) Old 07-03-2013, 06:38 PM
Bigtrev8xl's Avatar
5/8. 3/8 would make it worse
I DON'T DO RUSHING!
H-D dropping prices???? nanook *General Road Glide Discussions/Pictures 3 09-09-2015 06:41 PM
Dropping the bomb..... zombie Engine Related 5 01-16-2012 07:41 PM
Dropping a map into a SERT BigDaveOnBass ECM/Fuel Management systems 0 02-28-2011 08:52 AM
