Walter's Workshop Shift Lever - Road Glide Forums
post #1 of 4 (permalink) Old 12-27-2013, 09:23 PM Thread Starter
perrykw's Avatar
Anybody got experience with this? I received one as a Christmas present but it doesn't fit. Slides on the splined shaft perfectly, but the hole that's drilled in the lever looks like it's drilled a little off to line up with the groove in the shaft. The bolt won't quite go in. Also tried it on my wife's Street Glide. Won't fit hers either. The chrome looks great, but the fit is off just enough to not bolt up.
perrykw is offline
post #2 of 4 (permalink) Old 12-27-2013, 10:08 PM
faststan's Avatar
It don't matter without pictures.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 4 (permalink) Old 12-28-2013, 01:08 AM
I have one. I had the same issue. I just filed the slot in the spline where the bolt slides in a little bit. Worked fine after that.
Chofu73 is offline
post #4 of 4 (permalink) Old 12-28-2013, 11:21 AM Thread Starter
perrykw's Avatar
Thanks! I don't know why I didn't think about filing the recess. A little work with the dremel and it's finally installed. I still don't like the fact that I had to modify my bike to fit, but still cheaper than the HD version.
perrykw is offline
Walters Workshop Extended Shift Lever david-h Parts for Sale 2 04-11-2014 06:59 PM
Walter's Workshop Ext. Shift Lever RoadPilot Parts for Sale 2 01-29-2014 10:59 PM
Walters Workshop brake pedal WW-5B longrides Classifieds Archive (3 months old+) 0 08-07-2011 05:21 AM
FS: Harley Davidson Walter Boots brhodea Classifieds Archive (3 months old+) 2 03-25-2011 06:17 AM
