Cannot remount outer fairing , need help - Road Glide Forums
post #1 of 18 (permalink) Old 12-30-2013, 10:15 AM Thread Starter
searider's Avatar
hey Guys, I just put in daymakers and hogtunes amp and speakers, now trying to line up outer fairing hooks is driving me insane. anyone have this problem before and know why I cant seem to get the hooks to line up ? This is killing me .....im wondering if it might be the extra long wires and connectors that are added with they daymakers getting in the way but just not sure ... frustrated in Vancouver >>>>aahhhhhh
searider is offline
post #2 of 18 (permalink) Old 12-30-2013, 10:19 AM
ldireprophil's Avatar
I can't remember exactly what I read about this common frustration, but I know it has been brought up many times before. Hopefully someone will chime in or else I try to search the topic for older posts. Good luck!
ldireprophil is offline
post #3 of 18 (permalink) Old 12-30-2013, 10:26 AM Thread Starter
searider's Avatar
Im going to try taking the headlight out ...what a frustrating item ....thanks for the help
searider is offline
post #4 of 18 (permalink) Old 12-30-2013, 10:30 AM
wjco9's Avatar
Do a search for fairing removal, good thread gives all the details on how to get it back on, and yes taking out the headlight makes it easier.
Jay
Live to Ride
Ride to Eat
wjco9 is offline
post #5 of 18 (permalink) Old 12-30-2013, 10:37 AM
JayKS's Avatar
My fairing was much more difficult to install after I added Daymakers. I put up with it for a long time (including removing the headlights to install the fairing). Eventually, I cut the two three prong connectors and several inches of the harness out and re-soldered and heat shrinked (shrunk?) it all back together. Everything fits better and the fairing hooks up nice and easy.
JayKS is offline
post #6 of 18 (permalink) Old 12-30-2013, 10:42 AM
Brent376's Avatar
First, where are you in Van? I'm in Langley. Second, it us easier to push the light in after the fairing is hung... Not screwed, just hung in place.
JAWZ 2 / 2015 RGS /Custom Paint
Brent376 is offline
post #7 of 18 (permalink) Old 12-30-2013, 11:00 AM
I don't know if the daymakers make any difference because I am still running stock lights. Make sure that the wires are tucked in and/or zipped tied out of the way the best you can making sure the fairing mounting hooks a fully exposed. Make sure you don't have the light assembly adjusted to far back so adjust the light assembly as far forward as you can and still leave room for adjustment. Holding the fairing up to the inner fairing you can see where the windshield ends on both sides of the fairing, just pass that you will see the fairing makes a change which I call points. Line up the points of the inner and outer fairings, this will line up the mounting hooks to the slots in the outer fairing then lift the outer fairing up about 1/2 to 3/4 inch and push the outer in and then down, the outer should be on the hooks if done right. It may take a few tries but once you do it you will be surprise on how easy it is, if you are still having trouble you may want to take out the headlight assembly which many member find to be the easier way to mount the outer fairing.
post #8 of 18 (permalink) Old 12-30-2013, 11:06 AM
Venomized's Avatar
I always get it lined up with the edgrs of the innerfairing then give i a good pop with the palm of ny hand at the center top of the headlight edging and it pops on everytime.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #9 of 18 (permalink) Old 12-30-2013, 11:08 AM
OldNerdGuy's Avatar
Remove the headlights.
Hang the fairing without the headlights. Watch your cables and connectors, make sure they are available thru the headlight holes.
Take the headlights out of the mount. 4 phillips head screws per headlight. With Daymakers, they matter which side they go in. Note the rubber bushing on on each one, that goes towards the center when you put them back.
Now, finish mounting the fairing, complete with turn signals and top screws. Remember, the longer top screw goes in the bottom hole by the glove box.
Once you have the fairing mounted, time to put in the headlights. Start with the mounting frame, sans lights. This is where you may find an issue. With all the additional wiring, you might have blocked the adjustment screws from getting all the way thru to the holes in the inner fairing. They are the bottom two screws, and may be longer that before. They stick out in back of the inner fairing now. That makes it much easier to adjust the headlights. If you have a blockage, and it is just a matter of moving wire bundles, good. If not, you may have mounted the amp over the holes, or something like that. If you did, take the fairing back off, remove the blockage and start over.
Once you have the frame mounted, you can put the headlights back in. Pay attention to the rubber bushing on the lights, that goes into the new bracket you mounted on the fairing. Once you have the lights in, test them. Don't forget to test the ACC position on the key switch, that should light the Logo's in the Daymakers.
If everything is working, mount the bezel, stand back, have a beer (eh?) and enjoy your work.
Now that you know how to get just the headlights in and out, you can use that knowledge to take them in and out to get some access behind the fairing. This is useful when you replace your gauge lights with LED's ;-) Depending on how much room you have, how big your hands are, and what you've added, you should be able to reach the gauges from the headlight holes.
OldNerdGuy is offline
post #10 of 18 (permalink) Old 12-30-2013, 01:04 PM Thread Starter
searider's Avatar
im in Langley , and taking the headlight out and install the fairing worked ..not easy but it work .pain in the ass though ......but looks and sounds great ..thanks guys
searider is offline
What to buy? (when you cannot buy it all at once) hinerj Intake and Exhaust 8 07-25-2013 02:09 PM
You CANNOT fix Stupid! OldNerdGuy General Off-Topic Discussions 17 05-01-2013 08:36 PM
