Jacking around! - Road Glide Forums
 8Likes
post #1 of 37 (permalink) Old 01-10-2014, 11:58 PM Thread Starter
Tinsleytown's Avatar
Jacking around!
I have a Big Red Motorcycle Jack that i have no confidence in... the bike doesn't look like it sits level... my brother has a Sears jack that seems a little more sturdy... either way those things are difficult to load my bike on by myself. I've seen a couple of shops around town use a jack like these center jacks from K&L and I want to know which is the best...
Any of you guys use this style jack and if so is one better than the other? These center jacks seem easier to load a bike on and they get it up high enough for general maintenance or even cleaning wheels.
Just so you know, i used the "search" feature and i got every post about a guy named Jack or anything that began in a "k"
Tinsleytown is offline
post #2 of 37 (permalink) Old 01-11-2014, 12:26 AM
skratch's Avatar
i've never seen a jack like that used without a lift table before. everyone that i know that has one uses it on the lift. and i would be very nervous to try lifting a bike up high enough to do any kind of maintenance on just the center jack.
you are going to get a ton of opinions, but one thing that you will hear a lot more than anything else is to get either a j&s or a pitbull. are they expensive? you bet. are they worth it? you bet. either one is very easy to load your bike on by yourself.
i had a jack that i got from pep boys on sale (think it was a torin brand). that thing made me nervous as hell. i used it for a couple of years, but not as often as i would have liked. sometimes i would just do the job without it because it made me that nervous. even strapped down. gave it away, and got a j&s. i'm not nervous about it anymore and use it quite often.
skratch is offline
post #3 of 37 (permalink) Old 01-11-2014, 12:42 AM Thread Starter
I've seen a lot of guys around here use it on the ground for changing tires and stuff that doesn't require the bike to be at eye level... also heard of guys using it to make the bike more stable while trailering... snug the jack under the frame to keep the bike from bouncing around. My main use would be for polishing wheels and general cleaning/maintenance. what would be the difference in using it on the ground vs. on a lift? asking because I'm not experienced enough to know the difference...
post #4 of 37 (permalink) Old 01-11-2014, 05:17 AM
wjco9's Avatar
Got a Torin Big Red, use it all the time, I have to put it more to the back of the bike but goes on and off easy never any problems.
Jay
Live to Ride
Ride to Eat
wjco9 is offline
post #5 of 37 (permalink) Old 01-11-2014, 05:54 AM
skratch's Avatar
on the lift table the bike is secured with a wheel chock in the front, and/or tie downs. for taking the back tire off, it holds the bike level, while the rear section of the table is dropped for easy access to the tire/wheel.
i like the idea of using it on the trailer under the frame to reduce 'bounce', i've used a block of wood for that. but i don't trailer much, so that would be too much of an expense for me for that purpose. for doing back tires, i don't think it would go high enough, or if it did, i would be very nervous. and you've got nowhere to tie your bike down.
my j&s works great for doing wheels. and the side benefit is that you can jack it up high enough so that you can sit on a rolling stool and be comfortable while you're cleaning them wheels. but then again, i'm not as young as i once was. sitting on the floor may not be an issue for you. i just prefer not to. also, if all you are doing is cleaning wheels, the j&s/pitbull may be more of an expense than you want to pay. but i guarantee you, if you get one, you'll find a lot more uses for it.
Signedbybd likes this.
skratch is offline
post #6 of 37 (permalink) Old 01-11-2014, 06:11 AM
JacktheBagger's Avatar
Jay
same Jack here , oh wait I'm Jack
no probs with mine either
JtB
2011 Ultra
JacktheBagger is offline
post #7 of 37 (permalink) Old 01-11-2014, 06:20 AM
Like previously stated id be nervous about using the center lift jack without securing the front or having it in a wheel chock. I have a red sears craftsman jack that ive used for years without any concerns. I can jack it up, lock it in place and leave it that way for days. As far as loading it and because my bike is lowered sightly i put the bike on its side stand position myself and the jack on the right side and pull the bike upright and slide it under. Ill pump it by hand while holding the bike steady until its firmly positioned on the jack then pump away. Its easy peasy
post #8 of 37 (permalink) Old 01-11-2014, 07:10 AM
neverdone's Avatar
I don't remember which brand I've got but I also put it on the right side grab the handle bar and stand the bike up and slide the jack under it. I've used it on 2 metrics and now the harley. Hope to get a table this summer.
neverdone is offline
post #9 of 37 (permalink) Old 01-11-2014, 07:42 AM
Biljac's Avatar
I bought a J&S jack, rock solid and steady. Couldn't be happier with it.
Sent from Motorcycle.com App
Biljac is offline
post #10 of 37 (permalink) Old 01-11-2014, 07:43 AM
Quicksand's Avatar
Check out J&S jack. Look em up on youtube and check out the video!
Quicksand is offline
Wrap around backrest fit chopped tour pack? longrides Seating: seats, backrests 8 10-18-2014 12:23 PM
Jacking up a RG (or other touring bike) StriderJim Do-IT-Yourself 9 02-13-2013 04:33 PM
Proper jacking technique? Govdog76 *General Road Glide Discussions/Pictures 19 08-24-2012 08:17 AM
It's slow around here so I figured I would post some pics... FunkyNova66 *General Road Glide Discussions/Pictures 15 02-04-2010 10:16 AM
Seat moving around... Freaky *General Road Glide Discussions/Pictures 1 10-31-2009 08:56 AM
