Ness Radius Taillight assembly - Road Glide Forums
post #1 of 2 (permalink) Old 02-06-2014, 11:51 PM Thread Starter
NakedSnowman's Avatar
Getting rid of the stocker taillight and got the Ness Radius setup. Having some issues with wiring. Anyone install this on their ride yet? I have a 2010.
Stock wires are as follow:
V/BN+ \ Right Turn,Brake
BK- /
BE Running
V+ \ Left Turn,Brake
BK- /
BE Running
BK \
BK / Plate/Running
Ness kit:
R Brake signal
V Left turn
BN Right turn
BK Ground
BE Main taillight "run" power (powers all functions of taillight operation)
Now with that, the stock wiring of V/BN and BK control the brake and turn signals on the right. If I connect the wires according to instructions, how is the module going to distinguish brake from turn sig?
NakedSnowman is offline
post #2 of 2 (permalink) Old 02-07-2014, 10:44 PM Thread Starter
Well I figured it out. There was a post awhile back, https://www.roadglide.org/showthread.php?t=7140 ,asking a similar question with some leads...I found the entire service manual and grabbed it. Here's the correct wire diagram for a 2010 with details of what color is for what function.
I have a video of what the light looks like, but my fcking phone recorded it sideways....But what I did was follow the harness from the Tri bar light, up the left side saddlebag bracket to the fuse box. There is a connector there that you will find those wires listed. Without cutting them, I just removed about 4in of tape and striped the wires and spliced into corresponding color wire. And viola....Custom light works. I did tho, have to modify the fender some. The mounting holes do not line up properly. Maybe a 1/4" off. As well as the hole for the wire and support piece.
Also the O/W wire is for ACCESSORY.
Big radius 2-into-2 srs64 Intake and Exhaust 2 05-21-2012 03:33 AM
Freedom Exhaust Sharp Curve Radius Bodyarmorguy Intake and Exhaust 5 01-18-2012 06:40 AM
Review of Vance and Hines Big Radius tcon287 Intake and Exhaust 10 01-09-2012 02:25 AM
Anyone running V&H Big Radius? tcon287 Intake and Exhaust 17 11-11-2011 05:51 PM
V&H big radius 2 ino 2 build Indy Road Dog Engine Related 2 01-03-2011 08:48 PM
