Is blue tooth unit available to replace the wired headsets? - Road Glide Forums
post #1 of 14 (permalink) Old 02-27-2014, 01:45 PM Thread Starter
dgfltru's Avatar
I have a 2012 Road Glide Ultra and would like to use the full functions of the radio, CB, and intercom funtions but with out the need to plug the hardwire. I do not like being hard wired to the bike. Doe sanyone know of a Blue Tooth unit that will plug into the current radio/comms unit but blue tooth to the helmets?
2018 Road Glide Ultra, Electric Blue, Lowered Front and Rear, Heated HD grips.
dgfltru is offline
post #2 of 14 (permalink) Old 02-27-2014, 02:01 PM
Bull_Duck's Avatar
See my thread at
https://www.roadglide.org/showthread.php?t=116393
Bull_Duck is offline
post #3 of 14 (permalink) Old 02-27-2014, 05:23 PM
EZMotoTim's Avatar
I am not aware of any Bluetooth adapter that is bi-directional, i.e. allows you to listen to whatever is selected on the head unit and talk on the CB. (I have been looking for 3 years.)
2017 FLTRXS, Givi V56 Topcase, Windvest 10", National Cycle Hand Deflectors, Rapid Transit Tank Bag. My last bike was 2014 Triumph Trophy SE. Before that: 2010 FLTRX.
EZMotoTim is offline
post #4 of 14 (permalink) Old 02-28-2014, 12:18 AM
JacktheBagger's Avatar
I'm wit' Tim here , cant find a cordless that will let you use all the things on the Ultra . I don't like being hard wired either , but the audio is much better and I also splurged and got the longer cord for the headset ..
JtB
2011 Ultra
JacktheBagger is offline
post #5 of 14 (permalink) Old 02-28-2014, 01:22 AM
SmokeyJoe's Avatar
Would it be possible to use the BT dongle in the Aux port and have the GPS blue toothed to it so the GPS audio goes through the radio?
SmokeyJoe is offline
post #6 of 14 (permalink) Old 02-28-2014, 06:07 AM
EZMotoTim's Avatar
I suppose it would be possible to use a dongle into the aux input but that is much more expensive than running a wire from the GPS to the aux input.
If you have the Harley Road Tech 660 or 665 you could use the NIM. Look up other threads about the NIM. The NIM doesn't work with the Garmin Zumo 660 or 665.
post #7 of 14 (permalink) Old 02-28-2014, 07:14 AM
SmokeyJoe's Avatar
I have the Road Tech 660 as far as I know my bike does not have the NIM capabilities. I really like dont like the cable drapped across my bike while riding, and because of that I do not even use it. But if I could BT it, that would be cool.
post #8 of 14 (permalink) Old 02-28-2014, 07:29 AM
SmokeyJoe's Avatar
Maybe this would work - just saw this on Iron Cross Audio
"LOSE THE CORD!
Iron Cross Audio can now modify 2006-2013 Harley radio to receive Bluetooth streaming audio.
Just pair your Bluetooth enabled device to the radio, select "AUX", and Bluetooth audio can be played over your audio system.
To reactivate the aux connector just turn off your bluetooth device.
Mod is completely internal with nothing more to connect or mount.
MOD PRICE - $140
Please Note:
This mod is Bluetooth streaming audio only and does not support control of your Bluetooth device or hands free phone use."
http://www.ironcrossaudio.com/bluetoothmod.html
post #9 of 14 (permalink) Old 02-28-2014, 08:19 AM
EZMotoTim's Avatar
This is good, but still not what I am looking for. I want a dongle that provides audio OUT and microphone IN. It should plug into the jack for the headset cord.
post #10 of 14 (permalink) Old 02-28-2014, 09:20 AM
EZMotoTim's Avatar
You can add the NIM to your radio. You would probably want to have Iron Cross add a rear aux port to the radio as well. The BT mod sounds like a good way to go.
If you were to get a BT dongle to plug into the front Aux port, you'd still have it dangling. Not ideal, but it does eliminate being tethered to the bike.
Modular blue tooth helmets lundboy1 Helmets 9 04-25-2013 12:40 PM
Blue Tooth headsets...anyone use? Dmize Equipment-RG 17 02-25-2013 08:31 PM
Harley Davidson Road Tech Blue Tooth Helmet System longrides Sold 4 01-24-2013 07:33 PM
Blue Tooth sportyguy69 *General Road Glide Discussions/Pictures 11 10-31-2011 10:55 PM
Blue tooth comms...? GLYDDN11 Aftermarket Accessories 2 03-25-2011 07:32 AM
