Extended footboard mounts - Road Glide Forums
post #1 of 10 (permalink) Old 03-14-2014, 10:24 PM Thread Starter
Does anybody make extended footboard mounts at least 2" foward for 09 and later Road Glides ?
TRICKYRICKY is offline
post #2 of 10 (permalink) Old 03-14-2014, 10:58 PM
idahointrudr's Avatar
I think Kuryaykn?
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #3 of 10 (permalink) Old 03-14-2014, 11:26 PM Thread Starter
Originally Posted by idahointrudr View Post
I think Kuryaykn?
tried them but not enough , Arlen Ness use to have them but not no more I think
post #4 of 10 (permalink) Old 03-15-2014, 05:09 AM
longrides's Avatar
To go 2" forward you will need Harleys OEM +1 floorboard pan then add Kuryaklyns +1up and +1 out. The only lowers that will work with that setup is the Hogg Chopps.
I had this setup on my 08.
Currently Bikeless
Shopping for a '15 or '16 found one and it aint HD
2013 FLTRX Black Denim - 4" ceramic Jackpots, Fullsac X pipe header, PV w/FM map - gone but not forgotten
2008 Anniversary Edition,
gone but not forgotten.
longrides is offline
post #5 of 10 (permalink) Old 03-20-2014, 12:51 AM
Bossman1364's Avatar
I use the arlen ness 2 inch extensions and the kuryakyn 1 inch forward/1 inch out extensions. Total of 3 inches forward and 1 inch out. I'm 6 foot 4 with 34 inch inseam and this has been great for me. 7000 trouble free miles with this set up. I ride hard and rarely scrape either.
2013 Denim Black FLTRX: vance and hines pro pipe, madstad 14.5 inch
Bossman1364 is offline
post #6 of 10 (permalink) Old 03-21-2014, 02:09 AM
Taccone's Avatar
I have a set of 1" out and 1" forward floorboard extenders that I'll sell cheap! Tried them out and just didn't like them for myself. Then again I only have a 30 inseam so the factory setup is ok for me. I'll take 50 shipped if you want them, or any other reasonable offer.
Taccone is offline
post #7 of 10 (permalink) Old 05-14-2014, 11:34 PM
Willy's Avatar
Legends Vintage Motorcycles has 2" extended boards, and controls. Pricey, but excellent products.
'11 Road Glide Ultra
'04 Heritage Classic
Willy is offline
post #8 of 10 (permalink) Old 05-15-2014, 10:27 AM
yzergod's Avatar
I had the Harley Extended Length Rider Running Boards (part #50500158) on my Deluxe and then took them off an put them on my Road Glide. They are 4" longer (1" in the front, 3" in the back) and 1/2" wider than the Original Equipment rider footboards. They don't interfere with my lowers and allow for great foot placement options. HTH!
2001 SERG
yzergod is offline
post #9 of 10 (permalink) Old 05-15-2014, 11:31 AM
Craigmier's Avatar
Depending on your riding style you may not want to go that extreme with the floorboards. I would consider a seat that moves you back some and 1" extensions. with 2" extensions you will want to also get extended brake and shift levers. Also HW pegs for the long rides either way are key. I was in same boat as you and first did the kuryakyn 1" forward and out and it helped a lot but I still needed a lot more room so I did a custom seat rebuild which moved me back 2-3 inches that helped a ton. As you are pry aware, taller bars go great with all this stuff if you are a tall guy
'13 FLTRX - Big Blue Pearl - 16" Carlini Gangster Apes - V&H Power Dual Headers - CFR's - SE255 cams - SE Billet Cam Plate w/High Flow Oil Pump - SE Billet A/C - SERT - Dyno Tune - Daymakers - LRB Carbon Black Rotors - Progressive Suspension - H-D Vented Lowers - Bitchin Stitchin Custom Seat - Rockford Amp - Infinity 6.5's - GADS
Craigmier is offline
post #10 of 10 (permalink) Old 06-24-2014, 12:22 AM
MidNightRGU's Avatar
Ricky,
Haven't seen an up date, so thought I'd through my 2bits in...
I'm 6'6" with 38" inseam, started with Arlen Ness extensions. Had to remove the lowers, anyway due to heat allergy. Hard part is getting extended shifter & brake pedal. Wish I could remember where I found mine, took a while... Kuyakyns are not long enough.
MidNightRGU is offline
Reduced reach footboard mounts BH#103 Wanted! (Buy or Trade) 0 04-03-2016 06:23 PM
Passenger Adjustable Footboard Mounts Andyman Seating: seats, backrests 3 03-30-2014 01:34 PM
Flag mounts for the antenna mounts ndronet Aftermarket Accessories 3 08-21-2013 01:12 PM
Extended Reach Rider Footboard Pans - Traditional Shape longrides Parts for Sale 5 04-27-2013 06:09 AM
Extended Reach Rider Footboard Pans - Traditional Shape longrides Classifieds Archive (3 months old+) 0 06-25-2011 08:19 AM
