Air Horn Mounting Advice - Road Glide Forums
post #1 of 13 (permalink) Old 04-28-2014, 08:47 AM Thread Starter
Hello all,
I have a 13 FLTRU and I want to mount a wolo to it without it setting next to my engine. I think the horn is ugly but necessary. Where and how can I mount this horn? Pictures would be great.
Thanks,
cpo_roadglide is offline
post #2 of 13 (permalink) Old 04-28-2014, 09:26 AM
GermanyBert's Avatar
Have you purchased it yet? If not then check out the Mini Beast available ay Custom Dynamics.
I have the one that looks like the air filter cover and it is real nice. Makes a lot of noise!
http://www.customdynamics.com/mini_b...ycle_horns.htm
GermanyBert
2011 Road Glide Ultra
2002 Sportster 883/1250 Stage II
GermanyBert is offline
post #3 of 13 (permalink) Old 04-28-2014, 09:49 AM
mastergunnera8's Avatar
Not sure if you bought the wolo already or which one..but I used a piaa set, removed stickers, painted flat black; mounted to stock horn mount, opposing (you get 2 horns), and worked up a splitter from the stock horn wire..no problems in 13000mi..they are loud..
ride safe!!
mastergunnera8 is offline
post #4 of 13 (permalink) Old 04-28-2014, 09:57 AM Thread Starter
Originally Posted by GermanyBert View Post
Have you purchased it yet? ]
Yes, I already have it.
Having a heck of a time looking for a clear mounting point which is hidden but not blocked.
post #5 of 13 (permalink) Old 04-28-2014, 11:13 AM
TLWiz's Avatar
Originally Posted by cpo_roadglide View Post
Hello all,
Thanks,
Kuryakyn makes a cover that fits the Wolo (Stebel Nautilus) horn.
http://www.cruisercustomizing.com/co...r/part/KY-7732
TLWiz is offline
post #6 of 13 (permalink) Old 04-28-2014, 12:50 PM
Redbeard77's Avatar
This is just an idea so far, but I'd like to mount an air horn in the bottom triple tree area so it's at the front of the bike but not readily visible. Has anyone done something similar?
Happiness is a warm motorcycle.
Redbeard77 is offline
post #7 of 13 (permalink) Old 04-29-2014, 12:06 AM Thread Starter
Mount in front of battery
Someone mentioned in another thread, that the horn could be mounted in front of the battery in an area where there is some space. I would like to know more how this has could be done. I don't know how I can access that area. Does anyone have photos and or instructions?
post #8 of 13 (permalink) Old 04-29-2014, 12:14 AM
glide1's Avatar
I mounted my Wolo behind the right side cover, Relay and all-Fits nice and snuggly..
glide1 is offline
post #9 of 13 (permalink) Old 04-29-2014, 07:32 AM Thread Starter
In right side cover
That would be a good location but I have my Cobra FI2000 PowrPro mounted there and there is insufficient space now. My other concern about that location as in the Fairing, is would the sound be muffled and diminished?
post #10 of 13 (permalink) Old 04-29-2014, 09:51 AM
OldNerdGuy's Avatar
I did that on my Sportster with the same horn. Not sure it would work as well on the Road Glide.
I have the same horn, mounted in the stock location. I am not as concerned as some about appearance. Safety is higher on my priority list.
I would highly recommend you
. The stock horn does not draw much power, and it all goes thru the horn button. This guy does draw a bit more, and it has been known to burn out horn buttons. My Harbor Freight WOLO came with a relay.
I sanded down the WOLO on the outside and stuck a dealer dipping dot over it just to make it "official".
OldNerdGuy is offline
Best Aftermarket Air Horn Andyman Equipment-RG 13 11-22-2018 06:31 AM
Mounting bracket for Adjustable Rider Backrest Mounting Kit Part Number 52596-09A Oldbie Wanted! (Buy or Trade) 0 08-03-2017 10:24 PM
Air Horn Compressor - Where to Mount? Stray Mutt Equipment-RG 7 03-26-2013 12:59 AM
Now they'll hear me - air horn Uncle Fuzzy Safety Area 14 05-31-2012 06:30 AM
Air Horn METIME Aftermarket Accessories 4 08-25-2010 07:32 PM
