GADS Deflectors - Road Glide Forums
 5Likes
post #1 of 39 (permalink) Old 06-08-2014, 10:36 PM Thread Starter
GADS Deflectors
Got these put on today and they work great!!!!! No more wind swirling around my head. He shipped them out asap too.
scooterh72 likes this.
Nebraskarider1 is offline
post #2 of 39 (permalink) Old 06-08-2014, 11:46 PM
GADS deflectors
do you have lower fairings installed also?
i'm thinking about the GADS but wondering if they'll help since i don't run lowers. Thanks
stickman is offline
post #3 of 39 (permalink) Old 06-09-2014, 02:45 AM Thread Starter
No, no lower fairings just a stock FLTRX. I was ready to sell it and go back to an Electra Glide till I figured out it wasn't a windshield problem and heard about these.
post #4 of 39 (permalink) Old 06-09-2014, 07:14 AM
Just try adding a set of soft lowers to go along with the GADS.
grambo is offline
post #5 of 39 (permalink) Old 06-09-2014, 11:33 AM
I have a set of soft lowers but only use them in the morning. I heard they block the air from cooling the engine. Do you use them on warm/hot days?
vicsponjr is offline
post #6 of 39 (permalink) Old 06-09-2014, 11:48 AM
thanks Nebraska......I'll order a set based on your recommendation.
stickman is offline
post #7 of 39 (permalink) Old 06-09-2014, 01:22 PM
mastergunnera8's Avatar
Im wondering if they will fit with my crashbar mounted fogs...Ill have to do a little photo measuring when I get home...hopefully they will clear the mounting brackets..may give them a try!!
mastergunnera8 is offline
post #8 of 39 (permalink) Old 06-09-2014, 02:35 PM
PanWhenUCan's Avatar
Look into the Desert Dawgs soft lowers, you can run them regardless of the temp. They leave a larger gap between them than most of the other soft lowers allowing air to your motor.
I also have a set of Harley soft lowers, for me they are obsolete
I run the Desert Dawgs with the GADS package #1, Harley neck baffels and a 14" Windvest and get way better protection than on my EG Ultra with lowers. I run them up to 75 or 80 degrees.
Regardless of all the hype there is no 1 item that totally takes care of all the wind or turbulence. There are windshields that redirect the air coming over you fairing but you will still get the air up from under your fairing into your tank than your chest. The right products in combination will truely make your RoadGlide a wonderful riding experience.
Start with the least expensive and work your way up in cost. You will find your happy place.
Bob the GADS guy
PanWhenUCan is offline
post #9 of 39 (permalink) Old 06-10-2014, 11:48 AM
Used soft lowers w/GADS this winter, noticed a little less turbulance. But without lowers, noticed GADS also keeps some cold wind off the knees. Our weather here changes quickly,(warm to cold to warm) in fall and winter, so the lowers will stay on board then.
Amatt is offline
post #10 of 39 (permalink) Old 06-10-2014, 12:27 PM
vring's Avatar
+1! They made a big difference on my bike...
USMC 1982 - 2004
"There are only two kinds of people that understand Marines: Marines and the enemy. Everyone else has a second-hand opinion."
~Gen. William Thornson, U.S. Army~
vring is online now
GADS Deflectors rsscoggins Parts for Sale 3 04-10-2018 10:22 AM
FS: GADS smoke deflectors for 04-13 Road Glides Lu Parts for Sale 4 03-09-2018 02:07 PM
GADS/Deflectors jchar27 Parts for Sale 11 12-07-2017 10:47 AM
GADS #002 Deflectors Wings Parts for Sale 3 10-15-2013 09:43 PM
