Speedo/Tach console issues-Iron Aces GPS mount - Road Glide Forums
post #1 of 10 (permalink) Old 07-08-2014, 11:27 AM Thread Starter
OKBigD's Avatar
Anyone else notice their Speedometer/Tachometer console not staying together after installing their GPS mount? I took a 300 mile ride and after a few bumpy roads I noticed that the tab near the Key switch had lifted up... I probably had to push it back 3 times on a 300 mile trip.... Thought maybe this was due to the extra weight up top on the console.....
OKBigD is offline
post #2 of 10 (permalink) Old 07-09-2014, 03:21 PM
I had wondered about that. I do not have the mount and thought it pops out easy enough w/o a GPS on it
Slider1156 is offline
post #3 of 10 (permalink) Old 07-09-2014, 03:52 PM
Mischief's Avatar
That has occasionally happened to me too. One thing I did was use a little bit of black silicone when putting the housing back together. this seemed to help a lot
2012 FLTRU
Mischief is offline
post #4 of 10 (permalink) Old 07-09-2014, 04:09 PM
TXOSO's Avatar
I have had mine mounted for 2 1/2 years with never a problem, 15k miles on it. no issues, rock solid.
TXOSO is offline
post #5 of 10 (permalink) Old 07-09-2014, 04:22 PM
RebelGlide's Avatar
I have never ran into that issue with mine either
2013 Road Glide Custom..Big Blue Pearl
D&D fat cat, Stage 1 AC, HD Tuner, So Cal HID, 12" Malo's, 8" KW and 12" WV, and other doodads.
RebelGlide is offline
post #6 of 10 (permalink) Old 07-10-2014, 09:25 AM
mailman's Avatar
Mine comes apart with the iron aces mount just as you described. Plus on top behind the mount.
Sent from Motorcycle.com App
Billy
mailman is offline
post #7 of 10 (permalink) Old 07-10-2014, 09:38 AM
cobra206's Avatar
Ditto, in fact my hog-tunes tweeter unit has cracked just above the screws
cobra206 is offline
post #8 of 10 (permalink) Old 07-10-2014, 10:08 AM
DED HD's Avatar
I just have a painted inner fairing and no Iron Aces mounts or any mods and mine would do just as you are describing. Doesnt like to line up quite right, and sometimes I have to push down and pop that piece back in above the ignition switch. So it may not be unique to having the mount there, but i can see the added weight causing that.
'10 Red Custom:
DED HD is offline
post #9 of 10 (permalink) Old 07-10-2014, 10:11 AM
Bandit 7's Avatar
I've had the iron aces mount for over 20K and never any issues.
Bandit 7 is offline
post #10 of 10 (permalink) Old 07-13-2014, 10:53 AM Thread Starter
OKBigD's Avatar
Thanks for the replies guys sounds like it's fairly common for some people.... I'm going to try some extra heavy duty Velcro on top of the bar clamp..... I'll report back after Sturgis.....
OKBigD is offline
Anyone know if 10 FLTRX console insert fit a 06 FLHX console or 71288-03A console? chevjerico *General Road Glide Discussions/Pictures 6 05-11-2014 09:13 AM
Smartphone mount besides my Iron Aces GPS mount SEUGOT1 Audio 12 01-05-2014 07:33 PM
Iron Aces Road Glide iPhone/GPS Mount - 2011 RGC wachuko Do-IT-Yourself 11 06-01-2011 08:27 PM
Iron Aces GPS mount PGR Videos 0 04-10-2011 05:48 PM
Iron Aces GPS/iPhone Mount - Got Mine! G Aftermarket Accessories 1 03-08-2011 11:57 AM
