front fork springs?? - Road Glide Forums
post #1 of 12 (permalink) Old 08-09-2014, 01:06 AM Thread Starter
Just look for some feed back about changing the springs to stop the noise diving under hard breaking. I have looked at progressive,but there is not too many to pick from. Any information would be a great help! Thanks Freddy Rode
rodestar2 is offline
post #2 of 12 (permalink) Old 08-09-2014, 02:14 AM
skratch's Avatar
have you tried just changing the fork oil out? i switched from the stock oil to the se heavy and it improved the ride dramatically. is it as good as monotubes or some other upgrade? no? but it only cost $20 and it was good enough (for now )
skratch is online now
post #3 of 12 (permalink) Old 08-09-2014, 09:13 AM
faststan's Avatar
I changed out my stock springs for Profile-Low HD springs and it did away with the front end dive. I have since changed out for Monotubes and a great difference in ride.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #4 of 12 (permalink) Old 08-27-2014, 12:11 PM
Austinslider's Avatar
I'm using Progressive Monotubes. It's a stiffer ride, eliminates brake dive and better handling in the corners...
2011 FLTRU VH Power Duals, VH Monster Rounds, SE Heavy Breather, SERT, Bad Dad rear fender, extended bags, PYO 10" Monkey Bars, KW flare, PM Hooligan's (21/18) Bad Dad wrap front fender, PM lowers, Progressive monotubes. Audio: Kenwood X998, SS 4.1000D, Biketronics BT7P1 and BT474(rear pods).
Austinslider is offline
post #5 of 12 (permalink) Old 08-27-2014, 07:12 PM
Look up Ricor Intiminators. That's what you need. They work as advertised
inferno1976 is offline
post #6 of 12 (permalink) Old 08-27-2014, 07:37 PM
I would go with the monotubes. I did the progressive drop in springs and ricor intiminators on my streetglide when I added a 21" wheel. No brake dive but it always felt stiff.
2013 Ultra
Pics here:
rg_dave is offline
post #7 of 12 (permalink) Old 08-27-2014, 07:45 PM
If your going to change springs just go with the Monotubes. This way , no more worry about fork oil maintenence. Try the SE oil first and if still not happy buy the Monotubes. You should be able to get a set around $250.
post #8 of 12 (permalink) Old 08-27-2014, 08:20 PM
torqu's Avatar
I have a set of brand new progress springs I'd let go for $75.00 Brand new never been outta the box.
torqu is offline
post #9 of 12 (permalink) Old 08-28-2014, 09:19 AM
I installed the mono tubes when I changed out my lowers and I'm very happy with them. It was the best $250 I spent on the bike.
bbass is offline
post #10 of 12 (permalink) Old 08-28-2014, 10:12 AM
Mono tubes on my bike and I love them. You will have nose dive when braking with the mono tubes too but it is only about 25% of what you get with fork springs.
Besides the great ride and handling characteristics of the mono tube I like the fact that there is no more need to do front fork maintenance.
Using PVC spacers to preload front fork springs 96349 *General Road Glide Discussions/Pictures 10 02-17-2016 12:51 PM
Hot Springs, Pig Trail, Eureka Springs weekend ride throttles&triggers Road Trip Discussions/Stories/Pictures 2 09-08-2014 09:49 PM
Progressive Heavy Duty Fork Springs MakeARunMike Suspensions 8 05-15-2013 09:30 PM
Progressive Suspension Fork Springs jeff Classifieds Archive (3 months old+) 0 12-17-2011 02:09 PM
