Heads and cam upgrade - Road Glide Forums
post #1 of 12 (permalink) Old 08-23-2014, 10:50 AM Thread Starter
ewelty's Avatar
Hello, I have a 2012 RG Ultra with stage 1. I am going to upgrade the heads and cams via Dan Vance with Woods 777's. Any info/advise on this mod.
Thanks
ewelty is offline
post #2 of 12 (permalink) Old 08-23-2014, 11:16 AM
Thanks
The Woods 777 cam likes more compression so you would need to install high compression pistons to get the most out of the 777. Also you will need to keep your RPM range higher with the 777 because it isn't a good low end cam.
If you are leaving the cylinders and pistons alone and running lower compression there would be better cams for your build.
Unless you are running the bike balls to the walls and want to see who can get to the next tavern the fastest there is really no need for a big build.
For a 103 the stock heads will give you plenty of power with the right cams.
Look up some dyno sheets on some Woods cams on Fuel Motos web site and you will see that the 777 won't give you much more than the 222 and the 222 will be a lot better cam for the heavier touring model Harleys. JMO
post #3 of 12 (permalink) Old 08-23-2014, 06:41 PM
Mountainman's Avatar
Send a message via Yahoo to Mountainman
Smile Dan Vance and Fuel moto 777 power
You should look at the Dynos Fuel moto is getting with their pipes, head and pipes. The 777 is breaking 100 ftlbs at 2400-2600 rpm in 103's depending on the build. 100 ftlbs below 2700 is plenty as long as it keeps building.
Dan Vance knows what he is doing. Have him show you some dyno's so you know what to expect.
The 222 is a good cam but if you are doing heads at the same time the 777 and 888 can make as much low end as the 222 with more upper mid range and top end.
2013 FLTRU Big Blue Pearl:RB Racing LSR Spyder, SE255's (110/95), SERT, Boyesen Power x, DK intake vents,3"tank lift, t-pack relocator, Outlaw oil filter, Slipstream htd grips, l-s mirrors,adj backrest, 3t derby, sancho's wings, Ward's 160* thermostat, BigSky fans, Liquid Moly 10w-60, Rdeline VTwin Heavy Shockproof, B&M Trickshift, Burly ez clutch
Mountainman is offline
post #4 of 12 (permalink) Old 08-24-2014, 09:58 AM Thread Starter
ewelty's Avatar
Thanks for the info. I don't usually do the tavern/poker runs. Mostly long highway days so mid range to upper torque//HP numbers is what I'm after. I have heard nothing but great things about Dan and have a friend who did his head and cams with excellent results.
ewelty is offline
post #5 of 12 (permalink) Old 08-24-2014, 12:43 PM
If that is how you ride than the 222 is the better cam because it comes on early and it holds 100 ft lb of torque to 5000 RPM. The 777 comes on later but it will hold 100 lb of torque to 5000.
The 222 on a stock engine with exhaust and intake upgrades and a tuner will produce 112+ ft lbs of torque.
A 777 with exhaust, intake, tuner and CYLINDER HEADS upgrades only puts out 117+ ft lbs of torque.
That is ONLY 5 ft lbs of torque extra for a cost of a $1000 for the heads and thats if you do the engine work. That is $200 per ft lb for heads so IMO its not a good bang for the buck.
The money you save on heads can be better spent on other bling or a nice road trip or what ever. JMO
post #6 of 12 (permalink) Old 08-24-2014, 01:32 PM
ITOLDU's Avatar
What about the infamous triple nickel, 555 woods cam. I have a couple of buddies with them in both there roadkings 2010 models with 103 .... Both of them ran away from me when I had the 95" setup. Now since the 124" is in the objects/bikers in the mirror are NOT closer than they appear. All BS aside though check the 555 out.
ITOLDU is offline
post #7 of 12 (permalink) Old 08-24-2014, 05:50 PM Thread Starter
ewelty's Avatar
Upgrade
Thanks for the info. I got some budgeting/sorting to do now.
ewelty is offline
post #8 of 12 (permalink) Old 09-04-2014, 05:45 AM Thread Starter
ewelty's Avatar
heads and cams update
So I ended up with the Andrews 57H cams with s/s adj. push rods and thundermax tuner. I am installing this week and will advise back with results.
ewelty is offline
post #9 of 12 (permalink) Old 09-07-2014, 07:32 AM
Hammer Down's Avatar
I have the S&S 106, Dan Vance heads, SE adjustable push rods, Woods 555 and the woods roller lifters. I use power commander V and have had excellent results. Last Dyno was 110Hp and 115 torque.
It has more in it has well. it was running extremely rich from 2000-3000 RPMs at 100% throttle so it didnt really start pulling until after 3000 RPM's
I have worked that out but havent dyno'd again yet.
2010 RG Custom, S&S 106, Dan Vance Racing Heads, Cycle Rama 575 cams and lifters, SE Adj pushrods, Dan Vance 54mm Throttle Body, Dragos 2:1 Exhaust, DynoJet Power Vision with tunes from Fuel Moto customized by me.
Hammer Down is offline
post #10 of 12 (permalink) Old 09-07-2014, 11:41 AM
Road dawg's Avatar
I def agree with ironmark,too many people worry about heads and such,and their problem is an incorrect cam for there engine they are running,all that extra green for how many extra ponies,no way! Got to go for bang for your buck.
Road dawg is offline
Heads and cam on 2011 103 questions BigNorm Engine Related 20 01-04-2016 08:40 PM
Dragos new 565 cam with port heads and Dragula pipe DragoBikeWorks Dyno Results 27 10-10-2014 07:45 PM
Cam suggestions for 2000 also cam chain tensioner upgrade dirtracer27x Engine Related 22 04-09-2014 08:47 AM
twin cam 96" heads/103" cylinders and pistons JKRSDETROIT Parts for Sale 2 05-18-2013 09:03 PM
Just found some heads, what cam and pistons? 19Cobra96 Engine Related 0 11-05-2011 01:16 AM
