2015 RG Handlebars - alternatives?? - Road Glide Forums
post #1 of 45 (permalink) Old 09-16-2014, 09:06 PM Thread Starter
A friend purchased a 2015 recently and really doesn't like the handlebars. Has anyone changed theirs out yet? Please let me know the make and model.
Thanks.
Buiceman is offline
post #2 of 45 (permalink) Old 09-16-2014, 09:28 PM
tdkkart's Avatar
I think the first thing to do would be to re-position the stock bars and see if that helps. I sat on one the other day, i think if they were moved up so the grips were close to level they would be pretty good.
tdkkart is offline
post #3 of 45 (permalink) Old 09-17-2014, 12:10 AM
Loser21's Avatar
I don't like my 2015 stock bars at all. I am getting some custom ones made, but looking at the brackets and fit, most of the existing Trask and Yaffe bars that worked on 2013 models should be fine. If you use monkey bars or mini apes, I don't know if there is an improved clamp with three screws available yet, but that should be easy to work with if you find a pair of bars you like. If I have any other notes from my build I will post them up:
-LOSER21
2013 CVO RG - AtomicO/Grey
2009 RoadKing - Blue/Grey
Loser21 is offline
post #4 of 45 (permalink) Old 09-18-2014, 12:30 PM
FLTR AL's Avatar
Klock Werks Parts
Did you get a new 2015 Road Glide? They have parts! Check them out!
http://www.kustombaggers.com/2015hdfitment.htm
FLTR AL is offline
post #5 of 45 (permalink) Old 09-20-2014, 05:32 PM
Loser21's Avatar
Spooky Fast (Arizona) has these available starting Monday. Check out the website. www.spookyfast.com
-LOSER21
Loser21 is offline
post #6 of 45 (permalink) Old 09-24-2014, 06:39 PM
Sethjamto's Avatar
Attachment 147593
I don't see anything listed on their site for bars being available soon...
2015 Denim Black FLTRXS
14" Vindikta's - Rinehart True Duals - SE Heavy Breather Elite - Screaming Eagle Pro Super Tuner - King Tour Pak - 85.45hp / 104.41tq
Sethjamto is offline
post #7 of 45 (permalink) Old 09-24-2014, 06:55 PM
Garemlin's Avatar
I love that I love the stock bars in the position that they came. One less thing to worry about.
Garemlin is offline
post #8 of 45 (permalink) Old 09-24-2014, 08:29 PM
Same here. I find the stock 2015 bars put me in a more neutral/comfortable upright riding position then even the Heritage bars on my 2011.
regards,
2015 RGS
2016 R1200RT
Rsmith is offline
post #9 of 45 (permalink) Old 09-27-2014, 05:12 PM
Loser21's Avatar
There is a new notch and set-pin on the bars where the clamp locks them in...it will potentially limit the ability to roll them forward and backward to an ideal position. Makes them more stable once mounted, but it will be a challenge someone will have to solve. I am looking at cutting an extra slot so I can roll them back a bit.
-LOSER21
Loser21 is offline
post #10 of 45 (permalink) Old 09-27-2014, 05:13 PM
Loser21's Avatar
Pic for above comment.
-LOSER21
Loser21 is offline
Monotube spacer alternatives??? W_D_R Suspensions 3 01-12-2014 10:46 AM
legit and legal CABLE alternatives h-donut General Off-Topic Discussions 25 02-17-2013 11:24 PM
Poker run alternatives TracyB General Off-Topic Discussions 16 01-14-2013 07:59 PM
air pump alternatives? DWyellowRG Suspensions 10 06-05-2012 07:08 PM
