Will a older Tourpak fit my 2015? - Road Glide Forums
post #1 of 11 (permalink) Old 12-04-2014, 08:29 AM Thread Starter
Hey all , got a good lookin deal on a used Tourpak , fits a 97-13 FLH. Does anyone know if it would fit a 2015 FLTRX ?
Myrideisaglide is offline
post #2 of 11 (permalink) Old 12-04-2014, 08:35 AM
HenryG's Avatar
Tour Pak will fit
Yes, the older style tour Pak will fit as long as you use your bike appropriate mounts. Hope this pic attached. Here's what it'll look like.
H
To ride and to discover, is to be!
HenryG is offline
post #3 of 11 (permalink) Old 12-04-2014, 08:36 AM
124shark's Avatar
Yes and no.. If you have the mounts for the 15 you can drill a few new holes to mount it . But a direct fit no
2012 FLTRX 124 S&S
124shark is offline
post #4 of 11 (permalink) Old 12-04-2014, 12:59 PM Thread Starter
Talking Great
Got it, thank you guys. I'm gonna see what hardware I'm gonna need if I choose to go through with the purchase.
post #5 of 11 (permalink) Old 12-04-2014, 02:57 PM Thread Starter
More Infomation
It turns out the original tour pak rack is with the tour pak. So the trick would be making it work with my current docking hardware...does anyone have any idea what the hardware would cost to make this work?
post #6 of 11 (permalink) Old 12-04-2014, 04:39 PM
All you needo is a quick disconnect - 2009 up rack. They can be bought used under a Hundred Dollars.
post #7 of 11 (permalink) Old 12-04-2014, 07:59 PM
h-donut's Avatar
I think the 2009-up strut holes are similar, at least the two furthest back where a tour pack mounts, if it's a 09up it might work on the 15
I bought a 2014 ultra mount, liked the look, mounted perfectly to the 2010 struts
tied to line up a 2005 ultra pak, holes were off by 1/4" on each side in the front
and not even close in the back
but the holes for a 2010 chopped pak fit perfectly on the 2014 mount which fit on my 2010 FLTRX
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #8 of 11 (permalink) Old 12-04-2014, 08:07 PM
The holes in the 97- 08 tour pack are different then the 09 + packs. Easy fix , drill a hole in the rack.
post #9 of 11 (permalink) Old 12-08-2014, 08:44 PM
Yes, it will fit. I have one on my 15.
90b4032 is offline
post #10 of 11 (permalink) Old 06-14-2015, 11:56 AM
Mickeyv's Avatar
Henryg what did u do for the lights. Did u make a harness or buy one. Where did it plug into. I Was able to hook up my speakers with a harness. Iam thinking about putting lights on now. Thanks for the help.
Mickeyv is offline
Aftermarket Tourpak, OEM plate doesn't fit. dinggus Aftermarket Accessories 5 05-07-2017 12:55 AM
2017 Front Susp......Fit my 2015? SteadyEddie Suspensions 14 10-30-2016 11:17 AM
6.5" speakers that fit the tourpak pods Scootin Audio 43 03-29-2014 03:45 AM
Can TourPak liner 53302-07 fit in RGU/FLTRU? Lu *General Road Glide Discussions/Pictures 3 09-04-2012 12:18 PM
WTT Black Pearl Tourpak for Vivid Black Tourpak letsgofast Wanted! (Buy or Trade) 1 08-03-2012 02:54 PM
