Tour pak mounting bracket - Road Glide Forums
post #1 of 11 (permalink) Old 02-04-2015, 09:45 PM Thread Starter
Hello fellas. I've got a 2012 fltrx with a removable tour pak. I always had an issue with how far back the tour pak sits so I looked around to see if others with a removable tp had the same situation. Is there different types of brackets if you want the tp closer to the rider. I could see two holes showing on the bracket but I can't slide it forward. Any of you guys know a fix to this?
suomy1 is offline
post #2 of 11 (permalink) Old 02-04-2015, 09:47 PM Thread Starter
Couldn't turn the pic
suomy1 is offline
post #3 of 11 (permalink) Old 02-04-2015, 10:43 PM
Loose GSMCDE's Avatar
if you remove the liner in the bottom of the tour pack you will expose four bolts. you should be able to remove them and move the tour pack to the forward mount holes. it should move it forward about 1 inch.
Loose GSMCDE is offline
post #4 of 11 (permalink) Old 02-04-2015, 10:48 PM
lift up mat on bottom of tour pack. there are 4 bolts that go through to the mount. remove them and the tour pack can be moved forward about an inch. line up forward mounting holes and reattach the tour pack to the mount.
post #5 of 11 (permalink) Old 02-04-2015, 11:01 PM Thread Starter
There's a indent to where the bracket rest up against (tour pak) and it won't go any farther
suomy1 is offline
post #6 of 11 (permalink) Old 02-04-2015, 11:34 PM Thread Starter
I think I see where my issue is. This maybe for an earlier bike but with the newer bracket
suomy1 is offline
post #7 of 11 (permalink) Old 02-04-2015, 11:51 PM
just got mine mounted, it is the same as yours. Seams a little far back but im going to go with it. my tourpak is from a 95
Fnhracer is offline
post #8 of 11 (permalink) Old 02-05-2015, 09:49 AM
Just looked on ebay. There is a horse shoe shaped tube which is listed as tour pack mounting bar. Goes between mount and box. Might solve front to back issue but probably raises tour pack up about 1/2".
post #9 of 11 (permalink) Old 02-05-2015, 10:23 AM Thread Starter
Right on. I'll check it out. Hopefully it's for the newer model
suomy1 is offline
post #10 of 11 (permalink) Old 02-23-2015, 07:51 PM
nking262's Avatar
Yes, you do need the horseshoe shaped piece of tubing that goes between the actaul mount and the tourpak. Hope that helps.
Nick
nking262 is offline
Mounting bracket for Adjustable Rider Backrest Mounting Kit Part Number 52596-09A Oldbie Wanted! (Buy or Trade) 0 08-03-2017 10:24 PM
Tour pak mounting bracket. sjohn1024 Equipment-RG 6 12-18-2014 08:08 AM
metalsports tour pak rack on a 14 tour pak? longrides Aftermarket Accessories 0 11-05-2014 10:15 AM
Solo Tour Pack Mounting Bracket METIME Wanted! (Buy or Trade) 0 03-11-2013 09:32 PM
WTB King Tour Pak or Chopped Tour Pak- BLACK jimmyray11349 Classifieds Archive (3 months old+) 0 06-03-2011 11:29 AM
