Hells Foundry Adjustable Fairing Mount - Road Glide Forums
post #1 of 5 (permalink) Old 02-24-2015, 10:05 PM Thread Starter
One way or another I'm installing lower fairings on my 06 Glide. Has anyone have any history with the Hells Foundry Adjustable Fairing Mount? Looks like a good way to give me the clearance that I need.
BadBoBo is offline
post #2 of 5 (permalink) Old 02-24-2015, 11:02 PM
I want do this to my 06 too ! The brackets from Harley (all 3) don't cost much. Under $170 I think? And if you talk to PC pain (Jon @ Horney toad)You could get them even cheaper ! I have a set of Road Glide non vented lowers But honestly it gets way too hot !!!
johnnynitro is offline
post #3 of 5 (permalink) Old 02-24-2015, 11:41 PM Thread Starter
I was looking at that way also. I discussed it with the manager at my local harley shop today and we both had the same belief, that because the Glides frame changed in09 and the fact that the change also changed the neck configuration. most likely the mounts would not match up. with the adjustable one it would be more of a sure bet that i would not be taking the faring apart for nothing. Have you changed yours out yet?
BadBoBo is offline
post #4 of 5 (permalink) Old 02-24-2015, 11:54 PM
No not yet, BUT if you look at other posts on the subject seems allot of people have done this ! Some will say you don't really need to raise the fairing for vented lowers. For me I allso like the forward tilt of the 10 up braket Be careful of what the dealers tell you Their not trying to rip you off They really just don't know ! BUT keep reserching it !
post #5 of 5 (permalink) Old 02-25-2015, 12:05 AM
Bandit's Avatar
I'm sure you realize this, but they make lower fairings that fit the pre-2010 bikes... You can buy them on ebay for $300 including speaker pods if you like, or they're like $200 without.
If you are dead set on installing "vented" lowers, then go ahead and buy the brackets for the 2010 and later Road Glides... They fit just fine. Its been done several times.
Like I said, you probably know all that, but I simply wanted to make sure.
http://www.ebay.com/itm/HARLEY-DAVID...c58af0&vxp=mtr
2005 FLTR - 97" S&S Big Bore, Hillside Cycle Stage II Heads & Throttle Body Upgrades, S&S Rollers, Fueling Pump & Lifters, 570G Gear Drive, TTS, CFR's, Klock Werks Double Back, 104hp/106ftlbs. CB's Euro, PM Light Glide LED Kit, RC CZar Wheels
Bandit is offline
WTB Hells foundry or similar fairing mount Mike9z45 Wanted! (Buy or Trade) 4 07-31-2014 06:34 PM
Hells Foundry ADJ Fairing Mount ebertf Paint & Bodywork Section 7 08-01-2013 05:03 PM
Hell's Foundry Adjustable Road Glide Fairing Mount Shrug *General Road Glide Discussions/Pictures 4 07-31-2013 07:35 PM
HDwind deflectors with Hells Foundry Fairing Mount jnd42697 Windshields 4 06-08-2013 04:37 PM
Vented lowers with Hells Foundry fairing mount? IDRoadGlide Aftermarket Accessories 0 04-21-2011 03:41 PM
