Enclosed Belt Drive Primary - Road Glide Forums
post #1 of 7 (permalink) Old 03-05-2015, 01:28 PM Thread Starter
Well, I'm finally getting my motor put back together and in the process of the removal I found that my primary chain and the sprockets are pretty much toast as the previous owner using the dealer as his service point never had any adjustments done therefore the premature wear after +30,000 mi. Since I already have the bike torn down this far my thoughts are that I may as well go ahead and either go back together with new sprockets and chain or go belt drive.
After doing some research and pricing I have come to the conclusion that it may be a better option to just go ahead and switch over to a belt drive primary as they claim it can't stand to more power and there is a lot less maintenance. I am thinking of going with an enclosed system as to save on money, specifically this kit: http://www.jpcycles.com/product/600-792.
In addition, I am going back together with original my motor setup; a 95 cu in big bore kit, with the following upgrades: S&S 3 piece flywheel assembly and timken bearing conversion courtesy of S&S speed shop, +.005 high compression pistons 10.5:1 , +.005 cylinder bore. Keeping the 257 cams, and the heads are good; CNC ported and polished. Already has the upgraded SE cam plate with the hydraulic tensioner.
What are your guy's thoughts, experiences, and suggestions as to what I should go with if indeed this Rivera kit is the right one?
2006 FLTRI 95 Cu in., CNC, 257 cams, S&S flywheel, V&H 2 into 1 Pro Pipe, SE Super Tuner, Jim's 6 speed trans, custom paint, radio delete, enclosed belt drive primary, 18 in apes
2017 FLTRX Bassani Road Rage 2 into 1, SE Tuner, 18 in apes
hawk06Glide is offline
post #2 of 7 (permalink) Old 03-05-2015, 01:43 PM
JacktheBagger's Avatar
Rivera is a great set up , my only advice is go somewhere besides j&p , they are higher than d$#@ near everybody out there , even their gold club prices are higher than most peeps regular prices
JtB
2011 Ultra
JacktheBagger is online now
post #3 of 7 (permalink) Old 03-05-2015, 04:32 PM Thread Starter
JtB
Thanks for the response Jack! So this indeed is an enclosed system that would work on my bike? Where do you recommend besides J&P, which I simply used as an example, to purchase my kit?
post #4 of 7 (permalink) Old 03-05-2015, 04:46 PM
I haven't really compared prices, but I've often thought about going with belt drive and like one of the set ups I saw from Performance Machine.
post #5 of 7 (permalink) Old 03-06-2015, 08:08 PM
Man I love my belt drive factory primary on my 83 Shovel. In 32 years I have only broke 2 belts and both times the belt was under some serious distress at the hands of the souped up shovel.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #6 of 7 (permalink) Old 03-06-2015, 10:05 PM
FrankieB's Avatar
On your bike the only reason to go with a belt would be it is cheaper. The power it will produce, a chain won't have a problem. There is a bit of a learning curve to riding a belt primary bike. They can be alittle bit jerky at parking lot speeds with out the compensator.
06 RK
11 RGU
FrankieB is offline
post #7 of 7 (permalink) Old 03-07-2015, 06:34 AM
bigal51's Avatar
I had a beefed up shovel years ago and twice shredded the belt. I learned my lesson.
2017 Road Glide Ultra -STOCK!!! (so far) Member: Ironbutt Association
bigal51 is offline
FS Primo Rivera Primary Belt Drive wfowill Parts for Sale 6 07-20-2017 12:44 PM
BDL enclosed primary installation issue hawk06Glide Engine Related 7 04-10-2017 01:13 PM
Drive belt life mike *General Road Glide Discussions/Pictures 13 04-20-2015 09:01 PM
Belt Drive Primary? SIG556 Engine Related 3 12-08-2012 09:07 PM
Belt Drive Limited Compensator mrbill Troubleshooting for Road Glides 0 12-19-2010 08:00 AM
