T-Man Thumper Series 15 RGS - Road Glide Forums
post #1 of 5 (permalink) Old 03-06-2015, 01:43 PM Thread Starter
shagyluke's Avatar
So i have a 15 RGS. I want to send my heads to tman and have the Thumper kit installed. I dont know if this is going to take away from dependability as a touring bike. I could go with the Touring Elite kit and probably be a little better in that case, but at this point I am on the fence. Can someone give me there .02
http://tmanperformance.com/Kits/103-signature-thumper/
Thanks
shagyluke is offline
post #2 of 5 (permalink) Old 03-06-2015, 03:36 PM
tj316's Avatar
It says the thumper kit requires an after market throttle body , so if you weren't planning on replacing it too that's a point to consider
tj316 is online now
post #3 of 5 (permalink) Old 03-06-2015, 04:49 PM Thread Starter
shagyluke's Avatar
Yeah I seen that. One more reason I am on the fence. I was hoping that someone had gone that route and could give me some good insight. I will be patient and see if anyone chimes in.
Thanks
post #4 of 5 (permalink) Old 03-06-2015, 05:40 PM
So long as you keep the compression at 10.5-1 or less, you should be fine.
Call TR and tell him what bike and how /where you ride it, and he will fix you up.
My 117 has T-Man 625 Cams, CVO Street Performer Heads, Port Matched / Polished SE 58mm TB.
Everything is playing very well together. 15k miles of 2-up/loaded Sport Touring so far...
T-Man's Cams are my favorites.
HeatWave is offline
post #5 of 5 (permalink) Old 03-06-2015, 06:13 PM
You are better off with the pro touring kit. You will sacrifice some low end throttle response with the bigger ports. Call TR he will give you advise on your build.
I attached a 107 pro touring head with 662-1 cams at 11:0 compression sheet that I built for a customer.
sporacer is offline
2015 RGS & T-man Head work shagyluke Engine Related 4 04-14-2017 09:38 AM
2016 RGS or 2017 RGS? PEZRACER *General Road Glide Discussions/Pictures 11 09-01-2016 03:14 PM
Anyone go with denim black on a 15 RGS? Berms *General Road Glide Discussions/Pictures 38 10-19-2014 12:09 PM
Built up '15 RGS for $37k kyle31490 *General Road Glide Discussions/Pictures 26 09-21-2014 06:46 PM
Limited Series - Vaquero Series Anyone? wachuko *General Road Glide Discussions/Pictures 6 04-11-2011 10:35 PM
