Bad sissy bar fitment and chrome on a 2015? - Road Glide Forums
post #1 of 10 (permalink) Old 03-21-2015, 08:26 AM Thread Starter
I just installed the docking kit pn 52300353. This went on pretty easy once I figured out the horrible reference picture. Who makes these directions??
The sissy bar is 52627-09 and this is where I ran into problems.. At first I thought I had 2 different shocks with one being upside down..
This is the left side and everything looks good here. the sissy bar sat very easy on the notch.
This is the right side. The spring is half the size and set 180° from the other side. The sissy bar when vertical sits in the slot nice. Once rotate to horizontal it hits the top of the shock.
Immediately called my dealer who took the bags off another RGS and confirmed that it was the same way. After some more checking they have been knocking this side on with a rubber mallet and assured me it would break in after a while. To me this just says ill fitting at $180.00 and I expected more. Not really anything I can do besides change the shocks I guess.
During the install I was concentrating on the fitment and not the actual part. The next pic is on both sides in the crease of the bar and I am guessing a bad chrome job? I'm sorry but I expected more for what these parts costs. Is this a rare instance or is this typical?
2015 Road Glide Special
Bassani Road Rage 2:1
204 Cams
Screaminz is offline
post #2 of 10 (permalink) Old 03-21-2015, 08:35 AM Thread Starter
So apparently there is a TSB I missed from this thread..
https://www.roadglide.org/showthread.php?p=2342465
Now I guess its just a quality issue.
204 Cams
post #3 of 10 (permalink) Old 03-21-2015, 08:41 AM
sfcusaret2004's Avatar
I can't believe we're still discussing this issue. After months, EVERY dealer and service department in the world should have contacted each and every client to have their shocks verified. It is painfully obvious from the pictures that the first shock IS UPSIDE DOWN! If the piston and spring are on the bottom, your shock is installed backwards. Please, check your shocks and inform all of your friends to do the same!
sfcusaret2004 is offline
post #4 of 10 (permalink) Old 03-21-2015, 09:09 AM Thread Starter
10 minutes later and the shock is reversed with the sissy bar sitting right in the slot like it was made to go that way
204 Cams
post #5 of 10 (permalink) Old 03-21-2015, 09:32 AM Thread Starter
So my dealer is telling me no such TSB exists and not turn the shock around. I have searched online for M-1386A and cant find a thing. Can anyone confirm this 100%?
204 Cams
post #6 of 10 (permalink) Old 03-21-2015, 12:04 PM
oldredog77's Avatar
oldredog77 is offline
post #7 of 10 (permalink) Old 03-21-2015, 12:13 PM
oldredog77's Avatar
https://www.roadglide.org/showthread.php?t=182617
Actually the first photo the OP posted is the left hand side shock and it is in the correct orientation ,with the adjuster on the top, the second photo is the right hand side shock and it needs to be flipped end for end with the spring and piston on the bottom.
post #8 of 10 (permalink) Old 03-21-2015, 12:27 PM
My bad, Either way, THIS NEEDS TO BE CORRECTED BY THE MOCO NOW!
post #9 of 10 (permalink) Old 03-21-2015, 12:32 PM
oldredog77's Avatar
NP. Service manual page 2-79 states Manual adjust shock absorbers: Install both with the rod end down. install the adjustable one on the left with the knob facing forward.
post #10 of 10 (permalink) Old 03-25-2015, 02:48 PM Thread Starter
I did end up flipping it and the service manual is about the only thing in print from HD that I can locate. No problems at all after flipping it
204 Cams
Parts: 08 and under Sissy Bar, Streamliner Highway Pegs, Crash Bar Fog Lights bikerglasses Parts for Sale 0 02-07-2018 06:02 PM
Sissy bar and 2015 service manual MadMouser Parts for Sale 3 07-25-2017 04:40 PM
Sissy Bar Fitment FF/EMT222 Seating: seats, backrests 2 03-24-2016 08:38 AM
2015 Docking hardware and sissy bar help please HogPro *General Road Glide Discussions/Pictures 4 07-09-2015 02:28 AM
WTT CHROME 4point and sissy bar. buzzkill657 Wanted! (Buy or Trade) 1 07-16-2013 08:10 AM
