Wire harness - Road Glide Forums
post #1 of 3 (permalink) Old 06-13-2015, 03:10 PM Thread Starter
Wire harness
Ok, I cannot search yet on the fourm but, I know I read somewhere that there is a company that can make up wire harnesses. I installed a king tour pak on my Road Glide Special and the led lights that attach to the tour pak. I have the HD wire harness that connects to the led light bar in the tour pak. However I need a harness from this harness to connect to the one on the bike. I could not find a open pigtail for the tail lights. Apparently there is not one on the RGS. I checked the two empty pigtails in the left side panel but there was no circuit to the lights I need. I found the one that connects to the lower rear tail lights and thought of a wire harness like the ones for car trailers. You would unplug the existing harness at the pig tail and attach a splitter or Y so that you can reattach the existing rear tail lights and you would have another lead to go out to the tour pak lights/wire harness. Any help??? I just didn't want to cut the tour pak harness and do a in line wire connector.
rottman is offline
post #2 of 3 (permalink) Old 06-13-2015, 08:11 PM
perrykw's Avatar
Not sure about the entire harness thing, but www.wirecare.com sells pretty much every Deutsch connector that is on a Harley. I have ordered connectors from them when doing wiring projects so I could avoid cutting wires on my factory harness.
perrykw is offline
post #3 of 3 (permalink) Old 06-13-2015, 08:31 PM Thread Starter
Wire harness
Thank you for that information.
rottman is offline
09-10-11 Fairing Wire Harness Differences robertg Troubleshooting for Road Glides 4 10-18-2014 11:31 PM
throttle by wire harness ???? flatblackbastard Controls & Handlebars 15 06-24-2012 09:02 PM
Rear wire harness for Stop, Turn, Brake Seven3smoke *General Road Glide Discussions/Pictures 9 03-02-2011 05:40 PM
Added wire harness for rear speakers- It's a bitch! BDMastiff *General Road Glide Discussions/Pictures 8 08-29-2010 09:50 PM
Wire Harness audio overlay BDMastiff Aftermarket Accessories 3 08-14-2010 10:17 AM
