Banana Boards w 1"+1" extensions - Road Glide Forums
  • 1 Post By 93-331-29psi
post #1 of 7 (permalink) Old 09-17-2015, 09:40 PM Thread Starter
Andy N's Avatar
Anybody using cyclesmith banana boards 19" along with the kuryakin 1" out and 1" forward board extensions? My concern is reduced clearance in corners. I have a 2015 w 13" shocks (ohlins 2-2b) Do the boards drag easy, hard or not at all? How hard do you ride? Thanks to all!
Andy N is offline
post #2 of 7 (permalink) Old 09-18-2015, 08:25 AM
93-331-29psi's Avatar
I've got the cycle smith XLs and don't see a need for the 1" out 1" forward extensions. I had the extensions you mention with the stock boards, but I have no reason to use them now. With the XLs I don't even need/have highway pegs anymore. Lots of real estate on these boards.
RGKen likes this.
93-331-29psi is offline
post #3 of 7 (permalink) Old 09-18-2015, 08:34 AM
RGKen's Avatar
Originally Posted by 93-331-29psi View Post
I've got he cycle smith XLs and don't see a need for the 1" out 1" forward extensions. I had the extensions you mention with the stock boards, but I have no reason to use them now. With the XLs I don't even need/have highway pegs anymore. Lots of real estate on these boards.
My buddy was going to install the extensions when he got his XL Banana Boards but there was an issue installing them with the Banana boards and I can't think of what he said it was. Once he installed the boards without the extensions he said the exact same thing. Can't wait to get mine.
2018 FLTRXS
RGKen is offline
post #4 of 7 (permalink) Old 09-18-2015, 01:24 PM Thread Starter
Andy N's Avatar
The xl'S must be different in the way they fit than the 19"S with the 19"S the left board at the back by the primary is almost hitting and has no room to fold Up, on the right side as it folds it hits the exaust pipe. I wish I would have asked first. I did install the kuryakin 1" out and forward extensions. They fit well now and fold up like stock and are comfortable. I'm just concerned about cornering. I have done some searching Internet wise and most folks say no problem, we'll see.
Andy N is offline
post #5 of 7 (permalink) Old 09-18-2015, 01:37 PM
The XLs mount the same and have the same issue with hitting primary and exhaust. To answer the cornering question.... I drag them often and I don't consider myself an overly aggressive rider. If I put them out an inch I'd be dragging them a lot more.
post #6 of 7 (permalink) Old 09-18-2015, 01:58 PM
1extremeskier's Avatar
Have 13" shock rear and 21" tire in front stock tubes
XL BB + 1 +1 on extenders, but use the forum sponsor ones (cant think of name but hog something)
Lean hard and never scrapped, its the 13" rear that helps most and std 21" in front creates proper trail angle
2013 Candy Orange, MGS True Duals, SE A/C, Handlebar Lee 18" Cordovas, 21" Primo "CALI" Wheel, KW Level 21" fender, Progressive 444 & Monotubes, Kenwood KDC-X998, Biketronics BT4180, 7.1 PRO, 6X 9 in lids
Blacked out with some chrome for accent
1extremeskier is offline
post #7 of 7 (permalink) Old 09-18-2015, 03:34 PM
thedude's Avatar
I have the XL's with the 1 inch out spacers. I don't ride very hard but I have only scraped boards one time in probably 20k miles. Mike is a 13 X with 14 street glide stock shocks.
thedude is offline
Banana Boards w 1"+1" extensions Andy N Aftermarket Accessories 0 09-17-2015 09:38 PM
Cyclesmiths Banana boards: 18.5 or 21" 13-FLTRX Aftermarket Accessories 7 03-25-2013 05:42 PM
XL Banana Boards N8Dogg *General Road Glide Discussions/Pictures 23 10-15-2012 03:41 PM
Yaffe Banana Floor Boards Freaky *General Road Glide Discussions/Pictures 13 02-19-2011 07:59 AM
Upgrade-Banana Boards Roadie09 *General Road Glide Discussions/Pictures 14 01-23-2011 09:52 PM
