Extended Saddlebag Upgrade - Road Glide Forums
  • 1 Post By Smarty
post #1 of 4 (permalink) Old 11-05-2015, 11:42 AM Thread Starter
the88virgnian's Avatar
Looking to get new bags for my 13 RGU. Got a few options picked out, but was wondering about switching to the new style bag/lids (2014+). If I buy the newer style bags/lids, will they bolt right up to my current set up (13 RGU)? If it's going to require me to get a bunch of new hardware, I'll just stick with what I have.
2013 RGU BBP. Detachable Tour Pack, aftermarket slip ons (no name), Wild 1 WO612s, Avon Cushion Grips, 13" Madstad, Kenwood Excelon x799, 8x DD Speakers (4x VO-M, 2x CXS 6.5, 2x B3), Diamond Micro 4v2 Amp.
the88virgnian is offline
post #2 of 4 (permalink) Old 11-05-2015, 12:08 PM
Root76's Avatar
I also want the new style (2014 one-touch) extended bags, with the sweet rounded edge over the '13 with the angled-cut edge. I believe the '14 bags will work with a slight modification, however, the bags won't open with a '13 tour-pak. I'm not removing or replacing my tour-pak...
Midnight Pearl 2013 CFR pipes Khrome Werks handelbars
Root76 is offline
post #3 of 4 (permalink) Old 11-05-2015, 12:11 PM
Smarty's Avatar
Yes they will work with the older tour pak. You have to make a spacer. I seen 1/2 rubber hose between the tour pak and the bracket to raise it up just enough for the lids to clear. Lot's of things you could use to space it up some.
Root76 likes this.
Smarty is offline
post #4 of 4 (permalink) Old 11-05-2015, 12:16 PM
DED HD's Avatar
The hardware (hinge and latches) are expensive, but the bags will bolt up with a few adjustments to the mounting points. They aren't an exact fit on the bottom rails, but they fit. The saddlebags will sit further out on the back.
90200520 Latch assembly right $249.49
90200521 Latch assembly left $249.40
You can go aftermarket for less money. Fairing Plus has black for about $1000
Aftermarket Harley Davidson Extended Stretched Saddlebags with 2014 ONE TOUCH OPEN LATCH kit fit for 1993-2013 Harley Touring bikes Unpainted (New model 4.5 inch cut out)
'10 Red Custom:
DED HD is offline
D&D FAT CAT muffler and extended saddlebag question bigshaqa Intake and Exhaust 12 02-28-2017 09:57 PM
WTB saddlebag support bars for saddlebag guards PRWestlake Wanted! (Buy or Trade) 9 06-17-2015 08:41 AM
Regular and extended floorboards and saddlebag covers shrap Sold 2 04-13-2015 09:04 PM
FS: Custom Extended SaddleBag Skid plates GLYDDN11 Parts for Sale 41 01-21-2014 11:53 AM
Extended SaddleBag Skid Plates GLYDDN11 Equipment-RG 24 10-09-2013 07:07 AM
