Custom Dynamics LED Inserts - Install Question - Road Glide Forums
post #1 of 6 (permalink) Old 01-26-2016, 01:07 PM Thread Starter
Chris529's Avatar
I've installed the CD LED Inserts (front and back) on my 2015 RGS. They work and they are bright, but they don't sit quite right inside the housing. It's hard to explain (maybe I can add some pics later), but when I put the lens cover back on, the LED plate doesn't really true up in the space. It works, but it's crooked.
It's bothering me and I wanted to see if the group had any experience with this.
Thanks in advance.
-Chris
Chris529 is offline
post #2 of 6 (permalink) Old 01-26-2016, 01:25 PM
I just did mine. You need to twist the wires then coil them till they sit right.
Reno.
2015 RG Mysterious Red. Vance & Hines Monster Duals, Screaming Eagle Air Cleaner, FP3 Tuner, Coastal Moto Wheels, 10in. Freedom Shield, Custom Dynamics LED Turn Signals & light bar & alot of HD parts.
RGReno is offline
post #3 of 6 (permalink) Old 01-26-2016, 01:34 PM
Coil the wire and make certain they are seated in the reflector housing. You may need to trim some of the rubber gasket back so that it seats properly.
Just did mine, and it took a bit to get them lined up. And yes, they are bright. I installed the "run/brake/turn" on the rear along with the HD LED tail-light and it will get the attention of those behind you.
Mdwatson is offline
post #4 of 6 (permalink) Old 01-26-2016, 01:52 PM
IdahoHacker's Avatar
It does take some fiddling. The struggle is that the insert won't stay put while you snap the new lens on. I had to do it once or twice before the insert stayed straight.
Make sure you have the base correctly inserted so you don't have to do it again, and it does help if you carefully put the wires in a circle behind the insert.
2015 FLTRXS, SE Ventilator A/C, V&H Pro Pipe, S&S/Crane Chris Rivas Rocket 574 cams, Chris Rivas V-Twin dyno tune: 103 hp, 108 tq.
IdahoHacker is offline
post #5 of 6 (permalink) Old 01-26-2016, 03:49 PM Thread Starter
Chris529's Avatar
Good deal. Thanks all.
2015 FLTRXS
Vivid Black
Chris529 is offline
post #6 of 6 (permalink) Old 01-28-2016, 12:08 AM
You can go to the CD web site and they have very clear video"s on how to install them. Very informative...
VNVBRO is offline
Custom Dynamics LED turnsignal install tkbalt Do-IT-Yourself 65 04-06-2014 09:06 AM
Custom Dynamics LED signals ShitHouseRat Lighting 19 08-31-2012 06:17 PM
LED and HID lightings from Custom Dynamics Second Timer Lighting 8 03-13-2011 07:48 PM
Custom Dynamics Genesis II LED Tail light review Sonar_Chris *General Road Glide Discussions/Pictures 6 11-11-2009 06:19 PM
