Forward gear shifter problem - Road Glide Forums
post #1 of 10 (permalink) Old 02-20-2016, 04:08 PM Thread Starter
Question Forward gear shifter problem
I finally got out for my first ride on the new 2016 Road Glide. It was great however, I had difficulty using the forward shifter peg. My feet apparently do not turn in enough to effectively use the forward shifter peg. I had to use my heel for the front and back shifter pegs. Plus I am not use to floorboards and double shifters yet. Nevertheless, can I purchase an off set forward shifter arm or longer shifter pegs? I could not find anything looking online.
Thank you for any info.
canukHD is offline
post #2 of 10 (permalink) Old 02-20-2016, 04:35 PM
sj01fltri's Avatar
Give it time once you get used to them you wont want anything else.
sj01fltri is offline
post #3 of 10 (permalink) Old 02-21-2016, 08:15 AM
bucketlisthd's Avatar
They do make longer shifter pegs. You'll probably get used to the stock set up, though.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #4 of 10 (permalink) Old 02-21-2016, 10:04 AM
jeff338wm's Avatar
Couple options I'm looking at.
https://www.e-zbrake.com/
Welcome to The SoftBrake Company, Inc -
'13 FLTRX Candy Orange w/ an upgrade here or there
jeff338wm is offline
post #5 of 10 (permalink) Old 02-21-2016, 10:12 AM
Spazz's Avatar
Extended length shift pegs are out there (Google Search )... make sure your adjusted to your liking... some like them high up, I don't. I have mine low and shift heal-toe and will NEVER go back.
If you adjust them low ( like I did ) may sure the heal shifter ( when completely down and depressed ) is about 1/8" off the floorboard.. that way you can NEVER miss a shift.
Also... some insight for you... reaching NEUTRAL with the heal shifter is 100% easier if you haven't tried it yet....
RENO BAGGER AUDIO
Spazz is offline
post #6 of 10 (permalink) Old 02-21-2016, 10:17 AM
NorCal's Avatar
I extended my front shifter 1" and the rear 1 1/2". I also moved the floor boards out 1" which makes it a lot easier if you have big feet. I got mine at Baker Custom.
Extended Shifters Front Trans Levers for Harley Davidson : Sikk Shift Harley Davidson Custom Parts, - Baker Custom Inc.
NorCal is offline
post #7 of 10 (permalink) Old 02-21-2016, 10:18 AM
speedkills66's Avatar
I did two things. I removed the heel shifter which I never used and was sometimes in the way. And I added a spacer behind the toe shifter which moved it out into a more natural position.
heel-shift-lever-eliminator
2015 FLTRXS Road Glide Special
Jackpot 2-1-2 Header, Rinehart 4" Slip-Ons, HD SE Heavy Breather A/C, Road6 13" Standard Apes, PowerVision
115 TQ // 91 HP
speedkills66 is offline
post #8 of 10 (permalink) Old 02-21-2016, 12:27 PM
I have both levers adjusted low also. You barely have to move your foot to shift.
'87 FXR 100"
'79 Goldwing cafe
post #9 of 10 (permalink) Old 02-21-2016, 01:37 PM
! rock103 !'s Avatar
I also adjust them low. I think you will get used to it after awhile. Took me a little while coming from a Dyna. But love them now. If you don't get used to them or still wanna, check out longer front peg on eBay or something.
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #10 of 10 (permalink) Old 02-21-2016, 08:31 PM
Smarty's Avatar
I removed the rear shifter, pulled the front shifter off, pulled the shaft out and put it in the opposite way, put the rubber bushing on the shaft, then the toe shifter adjusted so my riding boot fits barely under it, then put the shifter lever on the back, pushed against the front shifter lever at the shaft and tightened the shift lever in the back. By doing this the rubber busing keeps the shifter from being loose and shaking and rattling. Works like a charm.
2016 RGS Black Quartz
Smarty is offline
Heated Gear and Rain Gear Stag556 Miscellaneous for Sale 7 10-27-2016 09:15 AM
shifter problem Kobrak Controls & Handlebars 8 08-27-2013 12:33 PM
Forward controls METIME Aftermarket Accessories 3 11-11-2011 12:53 AM
Jaybrake FL Forward Controls NTEXRG Aftermarket Accessories 2 07-02-2011 05:50 AM
accutronix forward controls Racer19 *General Road Glide Discussions/Pictures 1 04-22-2011 02:37 AM
