Gauges Not Working - Road Glide Forums
 7Likes
post #1 of 12 (permalink) Old 02-24-2016, 11:44 AM Thread Starter
Gauges Not Working
I have a 2016 RGS. I adjusted the handlebars. I used the maintenance manual step by step. I'm a little OCD. When I was done I found that the fuel gauge and the volt gauge do not work. no lighting, no function, no blinker indications. However the blinkers and brake lights all work. I re-checked the manual. I looked through all fuses. They still do not work. I used my Power Vision to make sure I didn't have any codes. as far as I can tell everything is together. In looking through the electrical section of the manual, the other systems that run on the same fuses have power. Any ideas?
jr2050 is offline
post #2 of 12 (permalink) Old 02-24-2016, 12:30 PM
! rock103 !'s Avatar
Check the connector that plugs into the speedometer and tach cluster. Sounds odd, but the system is looped together. Even though the speedo and tach work, if you have one bent pin in there it will compromise the system and fuel/volt gauges won't work. Don't ask how I know... lol
Spazz likes this.
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #3 of 12 (permalink) Old 02-24-2016, 12:32 PM
BTW welcome to the forum brother!
post #4 of 12 (permalink) Old 02-24-2016, 01:00 PM Thread Starter
I appreciate the help. I'll check it out first thing after work.
! rock103 ! likes this.
jr2050 is offline
post #5 of 12 (permalink) Old 02-24-2016, 02:20 PM
Smarty's Avatar
Howdy from Texas. When you open the speedo/tach cluster, there is a plastic connector holder in the back wall of the area where all this stuff plugs in.
2016 RGS Black Quartz
Smarty is offline
post #6 of 12 (permalink) Old 02-25-2016, 09:50 AM
Were you able to check it out?
post #7 of 12 (permalink) Old 02-25-2016, 09:55 AM
Spazz's Avatar
Gotta be the plug on the backside of the gauge cluster... it's the only plug back there for the cluster... may not be seated 100% or you may have bent a pin or two... check it good.
Swomack likes this.
RENO BAGGER AUDIO
Spazz is offline
post #8 of 12 (permalink) Old 02-25-2016, 10:08 AM Thread Starter
There was a bent pin. I straightened out. Everything works great. Thanks for all the help.
! rock103 !, Smarty and Spazz like this.
jr2050 is offline
post #9 of 12 (permalink) Old 02-25-2016, 10:24 AM
Spazz's Avatar
GREAT! Figured it had to be something easy....
RENO BAGGER AUDIO
Spazz is offline
post #10 of 12 (permalink) Old 02-25-2016, 11:06 AM
That's what happened to mine. And that's how I knew. Posted it here awhile back. Took me awhile to find it. Glad I could help
Spazz likes this.
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 12:09 PM
Fuel and Volt gauges stopped working... ! rock103 ! Troubleshooting for Road Glides 31 07-30-2018 03:48 PM
Gauges, indicators, speedometer, tachometer all quit working Hog Happy Active Military and Veteran's group 5 10-12-2016 06:32 PM
Gauges stop working. Any ideas? Willy_B Equipment-RG 5 05-04-2012 10:20 AM
Battery died, now speakers not working!!!!!! schnid72 Audio 11 02-12-2011 08:33 PM
