Wrong cam tool - Road Glide Forums
post #1 of 3 (permalink) Old 03-06-2016, 06:36 PM Thread Starter
Wrong cam tool
I finally decided to start on my cam removal today I had the gear locking tool, as well as the cam inner bearing removal/ installation tool. They are not cheap. So I get to the part where I have to pull the cam bearings and the darned tool does not work. It is not even close to fitting... Can't/ don't want to really go backwards at this point. Not too sure why it doesn't work. But the mandrel that is supposed to expand and capture the bearing for removal does not expand to capture the bearing I see no way for it to do that. The installation tool lets the bearing slip right over and keep going. There is no way it can push the new bearings in.
Prior to this issue, I used the gear tooth locker tool, It doesn't fit either.. URGGHH I am about to throw the whole damned thing over the cliff. What the hell am I missing here? Mine looks like the Jims cam removal tool. I dumped a bunch of money on tools that don't even work. Now my bike is in pieces on the shop floor, with no idea when I might be able to finish this project now This sucks big time.
Diverrick is offline
post #2 of 3 (permalink) Old 03-06-2016, 06:44 PM
Smarty's Avatar
Sent you a pm so you can call me.
2016 RGS Black Quartz
Smarty is offline
post #3 of 3 (permalink) Old 03-06-2016, 08:13 PM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
The Year Makes a Difference
There two different tools depending on the year of your bike. That might be why you're having trouble. You might be in a hurry but I could loan you the right one.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
Cam bearing removal/installation tool BigNorm Tech Area 5 09-01-2014 10:10 PM
Cam bearing installation tool Stag556 Wanted! (Buy or Trade) 0 09-01-2014 05:35 PM
Cam bearing tool question- stanggt Engine Related 6 04-15-2014 12:40 AM
Cam removal tool rental? jcmer22 Engine Related 5 07-27-2012 09:03 AM
