Recommend a cover up for the emblem on the rear fender? - Road Glide Forums
 10Likes
post #1 of 22 (permalink) Old 03-19-2016, 10:19 PM Thread Starter
turbochrisb's Avatar
Since I put the Kuryakyn blinker and license plate holder on the back...it's bugging me that half of the emblem is showing...I need something black to cover it up...I've searched but come up with nothing. Guess if worst comes to worst I'll get a black piece of vinyl and cut a piece out or something. Anyone know of a piece or a vendor that sells something made for this spot?
turbochrisb is offline
post #2 of 22 (permalink) Old 03-19-2016, 11:13 PM
mask around the area,scuff the metal ,just to remove any grease,road film or wax.prime with primer used on metal.paint and clear coat.i used a rattle can on my fender ext,worked great.the fender badge is out of the way so should be fine.
turbochrisb likes this.
diesel5 is offline
post #3 of 22 (permalink) Old 03-20-2016, 08:14 AM
1st Sgt's Avatar
You can peel the emblem off - it's just glued on, but there is a dimple and rivet under the emblem. Might want to see if it'll be covered up by what you have there already. Or find something else that you like to cover it up.
https://www.roadglide.org/albums/thum...?dl=1458475772
1st Sgt is offline
post #4 of 22 (permalink) Old 03-20-2016, 08:51 AM
! rock103 !'s Avatar
Yeah, I am sure it is just stuck on there with "harley tape"...
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #5 of 22 (permalink) Old 03-20-2016, 09:30 AM
hotrodad's Avatar
Try this
Get yourself a piece of fishing line. Work it under the emblem and saw back and forth. It should peel right off. Then deal with the sticky two sided tape left behind. You will have that rivet head to deal with but it won't look as bad as half an emblem.
Cheers!
2005 FLTRi
Black Pearl
Live to Ride ~ Ride to Live
hotrodad is offline
post #6 of 22 (permalink) Old 03-20-2016, 10:52 PM Thread Starter
Ahhh good info. Should be easier than I thought.
Thanks guys.
post #7 of 22 (permalink) Old 03-21-2016, 09:21 AM
It will peel right off. It's just stuck on with double sided tape. It covers the recessed bolt that hold a bracket on the inside of the fender
post #8 of 22 (permalink) Old 03-21-2016, 09:24 AM
I used a skull from HD to cover it up
diesel5, turbochrisb and Swomack like this.
post #9 of 22 (permalink) Old 03-21-2016, 09:45 AM
Swomack's Avatar
That worked out well right there.
Swomack
My Gallery / Click Below Link
Swomack is offline
post #10 of 22 (permalink) Old 03-21-2016, 10:43 AM
HD also recommends waxed dental floss to remove emblems. I used the floss to remove the emblems on the gas tank and it worked great and only about $2 at Wally World.
FLTRXS20 is offline
Canadian rear fender to U.S. rear CVO fender mikehall11 Lighting 10 06-05-2013 02:45 PM
RGU Tourpak emblem location? twowheel99 *General Road Glide Discussions/Pictures 14 11-18-2011 05:41 PM
looking for harley emblem (tank etc) ozbowhunter *General Road Glide Discussions/Pictures 3 04-29-2011 02:02 PM
Hog Tunes Tweeter Pod Emblem cleanrider Aftermarket Accessories 8 04-18-2011 05:20 PM
Which cams do you recommend? RoadGlide0611 Intake and Exhaust 21 10-23-2010 10:25 PM
