Raking the front end Questions - Road Glide Forums
post #1 of 10 (permalink) Old 03-22-2016, 12:39 PM Thread Starter
Been looking for my next project and am thinking of going with the larger wheel up front and raking the front. But as usual I have a bunch of questions.
I know cutting the head and re welding it is the "proper" fix but I see all the raked triple trees out there. Do they change the handling when compared to modifying the frame?
Can I do the rake now and leave the factory small tire for now? this is all going to cost some $$ so thinking of doing it in stages.
Which one of the many triple trees out there are the best ones?
How much rake do I add? been looking for pictures of different rake angles but not finding much details.
l plan on installing the progressive tubes while I am there.
Also can I keep my factory rotors or do those have to be bought as well, to fit the rim? Don't want to loose my ABS. Not sure if there is a standard bolt pattern for all of this stuff.
Diverrick is offline
post #2 of 10 (permalink) Old 03-22-2016, 03:29 PM
dbbarton00's Avatar
How big you wanting to go?
I am currently having HHI x23 trees and 23" front wheel installed. Have not road on over 21" yet. here's a little I've learned:
23" you can do trees only 6 deg's rake or you can cut the neck 7 and rake 7 which will put the front wheel out a little farther. Either way you get correct trail.
26" must cut and rake.
You cannot safely run the stock wheel after raking.
check out HHI website or Hog Pro's bike gallery tab on his site. Also choppedbaggers.com has a lot of photos and info.
dbbarton00 is offline
post #3 of 10 (permalink) Old 03-22-2016, 03:29 PM
Dragon Dude's Avatar
MC Baggers looks like a good product. They show an install on U tube. Looks like a quality product, but someone with them might chime in and give you more info.
Dragon Dude is offline
post #4 of 10 (permalink) Old 03-22-2016, 06:56 PM Thread Starter
i was thnking of going up to a 23 inch wheel.
post #5 of 10 (permalink) Old 03-22-2016, 06:57 PM
Smarty's Avatar
Or, you could just do this!
2016 RGS Black Quartz
Smarty is offline
post #6 of 10 (permalink) Old 03-22-2016, 07:20 PM
lil chief's Avatar
I like that!!
lil chief is offline
post #7 of 10 (permalink) Old 03-22-2016, 08:38 PM Thread Starter
What was done to get this looking like that? That's bad azz!
post #8 of 10 (permalink) Old 03-22-2016, 08:59 PM
Smarty's Avatar
Same size tire on the front that's the back. Lowered front end, and probably air bags on the back. Looks like he might have Lowered the front fairing too which I really like.
Smarty is offline
post #9 of 10 (permalink) Old 03-22-2016, 09:04 PM
dbbarton00's Avatar
Picked up the bike 23" HHI x23 trees.
Rides great!
post #10 of 10 (permalink) Old 02-01-2018, 10:34 AM
I've been planning my mods to my 08 and going with a 23" is one of them. I have read hundreds of posts, talked with several riders who have gone with 23" wheels and there are two ways to go about it.
I went with option "1" and purchased through Pickard USA as they were the first company to design and produce and guarantee 100% wobble free.
1) You can install a 6 deg triple tree and will not have any issues. Though I recommend going with one of two manufactures for the triple trees (HII or Pickard USA)
2) BUY a bolt on neck extension kit and install triple trees, however talking with Pickard USA, you do not need to do both unless your looking for that wheel to frame spacing look.
3) If you do the cut and weld neck extension, I've been told A) it will void any warrant and B) now you have frame that's technically a salvage
HD-RG-SD is offline
Front End Wobble on RG/Service Bulletins jjyoung Troubleshooting for Road Glides 435 04-13-2016 03:43 PM
Polished front end questions... Bluefilhd *General Road Glide Discussions/Pictures 12 01-05-2015 01:13 PM
Questions about lowering front end biackbenz Suspensions 3 07-11-2012 08:18 AM
front wheel or front end jonessigns Troubleshooting for Road Glides 0 05-07-2011 04:02 PM
Chrome Front End Cheeze *General Road Glide Discussions/Pictures 4 12-16-2009 08:08 AM
