Monotube questions - Road Glide Forums
post #1 of 13 (permalink) Old 03-31-2016, 11:51 AM Thread Starter
Monotube questions
I recently ordered a set of Progressive monotube Front suspension for my 2013 RG. All they offered was standard height for that year and model. While waiting for it to arrive I got to reading about the lowered style on monotube. I don't understand this. The instructions say that in order to lower it 1 inch you add 1 spring, in order to lower it two inches you add two springs. Hos can ADDING extras springs lower the stance? Logic tells me that using SHORTER springs or less springs would be the way to lower it? I contacted Progressive and they told me if I wanted to lower it, I should have bought the lower style monotubes. I wrote back that the lowered version was not offered for my make and year, and then I heard nothing back from them. Can anyone explain to me how adding top out springs, lowers the bike? I was thinking I could install a spacer maybe to the standard height tubes. Or find the longer "lowering spring" I am just not fully understanding how this works.
Progressive told me that if I tried to lower using the stock monotube I would start bottoming out. I have a machine shop at my disposal, so I am not adverse to changing some internal parts to stop the bottoming.
Diverrick is offline
post #2 of 13 (permalink) Old 03-31-2016, 12:11 PM
anonymous_1's Avatar
I stuck with the stock height while adding a 21" front. I don't really know what you're talking about with adding springs. After installing my kit that don't really make sense to me either. But Progressive really seems to know what they are talking about. I got my kit from Hogpro with my wheel, I think they had the kits for lower than stock, maybe call and ask them? Either way, good luck.
2013 Road Glide Ultra, House of Kolor custom paint, 4" Rinehart true duals, Fuel Moto AC, Power Vision, Covington covers, Biketronics 7.1" front and rear with BT4180 amp and Alpine 164bt, Hogpro 21" 6-pack
anonymous_1 is offline
post #3 of 13 (permalink) Old 03-31-2016, 12:19 PM
turbochrisb's Avatar
They're tech support is pretty helpful......nice guys. Give em a call.
turbochrisb is offline
post #4 of 13 (permalink) Old 03-31-2016, 12:34 PM
! rock103 !'s Avatar
I just did the install on my 2015. It does seem illogical that adding springs will lower the shock. But it does. My kit came with 6 top out springs (I just used two, one in each leg, to lower 1"). Lemme know if they'll work with your model year and I can send you a pair. Here's a picture of the 1" lowered comparison:
lil chief likes this.
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #5 of 13 (permalink) Old 03-31-2016, 01:28 PM
calgaryglide's Avatar
Here is the link to the lowered kit on their website.
http://www.progressivesuspension.com...u-2013-touring
click on the options tab and you will see the lowering kit with springs. Kit # 31-2501 $439.95
I ran these lowered 2 inches in my 2008 FLTRi with a 21" wheel. They worked fantastic, stopped the front brake dive and the bike handled way better in my opinion.
I also ran the 440 series rear suspension as well and replaced the front motor mount and rear bushings with Glide Pro. I believe that the combination made of Progressive and Glide Pro made the bike handle so much better.
Regards,
Calgaryglide
2019 FLTRU, Tyggr
calgaryglide is offline
post #6 of 13 (permalink) Old 03-31-2016, 01:29 PM
lil chief's Avatar
Did the same thing a couple months ago. I've lowered several bikes using progressive products & yes, logic would tell you that adding components would raise the suspension, but it's the opposite on these systems.
Lil Chief
lil chief is online now
post #7 of 13 (permalink) Old 03-31-2016, 03:14 PM Thread Starter
So it sounds like if I added a 1/8 or 1/2 inch spacer under the topping spring the standard kit came with, it would effectively lower it then? Maybe even washers would work. I cannot see the pics for some reason, all I see is a big "-" sign.
I sure would like to see the height difference between the lowered ones and standard.
post #8 of 13 (permalink) Old 03-31-2016, 03:16 PM
The internals are different between the two monotubes. When the spring(s) is added to the dampening rod it will then raise the lower leg when the bolt is reinstalled, thus lowering the front end. Just some the install on mine, the lowered version put the frame down hill on my fltrx. Used such height version and it sets perfect.
Sent from my LG-H900 using Tapatalk
wfowill is offline
post #9 of 13 (permalink) Old 03-31-2016, 03:24 PM
Try this one...
post #10 of 13 (permalink) Old 04-01-2016, 03:32 AM Thread Starter
Ok that one worked. I'll measure my hight tomorrow and pm you. Thanks
A couple questions - which monotube and shock? turbochrisb Suspensions 5 04-03-2015 03:06 PM
Monotube questions bcultra Suspensions 12 03-13-2014 04:51 PM
progressive monotube install questions pimpsarus Suspensions 3 12-10-2012 03:29 PM
Lowered 2" Monotube questions Jaystew Suspensions 5 05-18-2012 05:52 PM
Proggressive Suspension Monotube Kit akjeff *General Road Glide Discussions/Pictures 6 07-30-2010 10:47 AM
