2013 14" apes what's needed? - Road Glide Forums
post #1 of 7 (permalink) Old 04-27-2016, 10:50 PM Thread Starter
Hey guys just bought a 2013 RG and putting 14" apes on it but have no clue what I need and no clue the best place to get it. Wires ect...
Thanks for any help
Chrisodell is offline
post #2 of 7 (permalink) Old 04-27-2016, 11:08 PM
SmokeyJoe's Avatar
Subscribed
SmokeyJoe is offline
post #3 of 7 (permalink) Old 04-28-2016, 02:59 PM
TLKurtz's Avatar
Send a message via Skype™ to TLKurtz
If you're looking for a complete kit you can try Hill Country Custom Cycles out of Texas. Just be aware that contacting them pre and post sales is a PIA. Other than that, you can get the separate pieces for the entire project on your own. Just search the threads for handlebar projects and you'll find all the info you need.
-TLKurtz (Mr. Wizard) - Blackhorse Cavalry Nomads VMG member (2/11 CAV - East/West German Border)
2015 RGS - Vivid Black and loads of fun.
Reside in Vegas. I keep cold beer in the fridge for all visitors.
TLKurtz is offline
post #4 of 7 (permalink) Old 04-28-2016, 03:13 PM
93-331-29psi's Avatar
Call these guys and tell them the bars you're using and they'll get you fixed up. They take all the guess work out of it. I've done 3 bar installs and they've nailed it each time.
www.hdbikeparts.com
93-331-29psi is offline
post #5 of 7 (permalink) Old 04-29-2016, 02:49 PM
DED HD's Avatar
i put 14s on my 2010 and didnt change anything. all stock wires. I eventually bought a longer clutch cable tho, as it was a little tight.
Other than that, some new poly bushings.
'10 Red Custom:
DED HD is offline
post #6 of 7 (permalink) Old 04-29-2016, 04:14 PM
TYM2GLIDE's Avatar
I put 14s on my 12 RGC, I extended the wires for each side of the controls bought a kit that matched the color of the factory wires, was so easy. I had to extend the fly by wire (and I cut out the green plug, bike is much more responsive). Extended upper brake line (black pearl with lower to match) and an extended clutch cable.
If you get a bar w/ "meat hooks" make sure it is a company that deburrs the inside before welding because it will make internal wiring much easier. I went with Buky Bars 14" Malo's. The go by Factory 47 now. I could not be happier w/ these bars.
good luck.
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #7 of 7 (permalink) Old 04-29-2016, 11:48 PM
nsbohall's Avatar
I did the wire extensions, riser bushings and clutch cable. I was able to use the stock brake line with no issues but may change it just for the aesthetics. The bike is a 13 RGU with 14" Carlini Pist.
2013 FLTRU, S&S Power Tune Duals, Supertrapp Stouts, Andrews 48's, AN Big Sucker, Direct Link, Fuel Moto LED's, Custom Dynamics, 14.5 Madstad, 14" Carlini's, Legends AXEO and Revo A's.
nsbohall is offline
stock 16" shield hits new 14" apes 2" shy of fork stops. Will a Mako fit? chevjerico Windshields 0 12-04-2013 12:02 PM
any pics of Carlini 14" flying apes (1.25") Tatude Controls & Handlebars 4 04-23-2013 09:14 AM
HELP! 11" or 14" apes? DED HD Controls & Handlebars 18 11-01-2010 07:09 AM
