Detachable Tourpack Compatibility 13/16 - Road Glide Forums
 2Likes
  • 1 Post By RGKen
  • 1 Post By RGKen
post #1 of 9 (permalink) Old 07-23-2016, 12:48 PM Thread Starter
Hi
Well I just traded my 2013 RGU in on a 2016 RGU
I removed my 4 point docking hardware and reinstalled the tourpack with the original mount
I know the 4 point won't work on the new bike but does anyone know if the detachable mount from my old setup will work on the new bike?
Thanks for any info!
Aslaytr is offline
post #2 of 9 (permalink) Old 07-23-2016, 02:42 PM
RGKen's Avatar
Both models docking hardware (09'-13' & 14' -current) accept the same accessories.
Aslaytr likes this.
2018 FLTRXS
RGKen is offline
post #3 of 9 (permalink) Old 07-23-2016, 02:48 PM Thread Starter
Thanks
Aslaytr is offline
post #4 of 9 (permalink) Old 07-23-2016, 02:53 PM
lil chief's Avatar
As said, I'm running an 09-13 pak on my 2015, using the 09-13 detachable mount. It works just fine, but some have had to shim the pak up a bit to clear the bag lids. I didn't have to, mine clear by about 3/16"-1/4".
Lil Chief
lil chief is offline
post #5 of 9 (permalink) Old 07-23-2016, 02:59 PM Thread Starter
Thanks
It looks like all the wiring is already set up with disconnects to make the removal easier too
Aslaytr is offline
post #6 of 9 (permalink) Old 07-23-2016, 04:50 PM
RGKen's Avatar
Originally Posted by Aslaytr View Post
Thanks
Well now the wiring is a different story. You will have to change the plugs on the TP to match up to the rushmore plugs. The rushmore bikes have a canbus electrical system and the connectors are different.
2018 FLTRXS
RGKen is offline
post #7 of 9 (permalink) Old 07-23-2016, 06:58 PM Thread Starter
It's only the mount I'm reusing from the old bike. The new one is an ultra also.
Aslaytr is offline
post #8 of 9 (permalink) Old 07-23-2016, 07:01 PM
RGKen's Avatar
Ok. You will have to drill new holes in the mount to accept the new style TP but it will work that way.
Aslaytr likes this.
2018 FLTRXS
RGKen is offline
post #9 of 9 (permalink) Old 07-24-2016, 01:10 AM Thread Starter
Hmm the old bracket is narrower. The holes would have to be along the edge where it dips
Did you mean to drill the tourpack to run new bolts?
Aslaytr is offline
Bluetooth Headset Compatibility woverby Audio 3 06-19-2017 11:56 PM
2017 RGS CB compatibility Azblu Audio 0 02-23-2017 10:47 PM
Tourpack pad withouth tourpack dav.elis Seating: seats, backrests 6 10-03-2016 11:30 AM
Part Compatibility? rocus *General Road Glide Discussions/Pictures 4 06-20-2013 08:29 AM
Speedo compatibility Monkeyman *General Road Glide Discussions/Pictures 0 05-13-2012 11:51 PM
