steering dampers - Road Glide Forums
 2Likes
post #1 of 11 (permalink) Old 10-11-2016, 04:22 PM Thread Starter
steering dampers
Hey so I dont know if I'm the only one but on my 2011 fltrx i have 14 inch apes and it seems to get a little bit of speed wobbles once I get over 90 but I was wondering if anyone has ever put on a steering dampener to stabilize their ride? if anyone has please post a picture and tell me where you got it and if it is truly worth it.
killgorejohn is offline
post #2 of 11 (permalink) Old 10-11-2016, 09:45 PM
MightyWhitey's Avatar
You do not need a steering damper on your glide. You need to adjust your steering head bearings. do you have a service manual? If not I could take pictures of the adjustment pages and email or text them to you.
MightyWhitey is offline
post #3 of 11 (permalink) Old 10-11-2016, 09:50 PM
If it's not your bearings you've got a wheel or suspension problem. Definitely a problem though that you wouldn't want to cover up with something like a stabilizer.
SteadyEddie likes this.
post #4 of 11 (permalink) Old 10-12-2016, 08:41 AM
SteadyEddie's Avatar
Mr White is right.........Dampner is only masking your issue and you really only need one on a bike you are racing to pay your bills - These pigs should not be tank slapping
SteadyEddie is online now
post #5 of 11 (permalink) Old 10-16-2016, 02:15 AM
Well Killgore, did you find anything wrong with the scoot?
post #6 of 11 (permalink) Old 11-10-2016, 04:53 PM
taoist's Avatar
Steering Dampers
I was in a HD dealership on Monday 11/7 waiting for my bike to be serviced and started looking at the 17 tri-glides. They now have steering dampers on them. Just the tri glides though, have not looked at the free wheeler (road king trike).
2006 Black 95 cu in Dyna Street Bob
2017 Black Road Glide Special
taoist is offline
post #7 of 11 (permalink) Old 11-10-2016, 06:39 PM
Guessing that's because of the push while cornering as the triglide doesn't lean like a two wheeler so it's going to want to push that front wheel when it's turned and that will make it hop which will translate into jerking handlebars. just a guess though.
post #8 of 11 (permalink) Old 11-10-2016, 07:13 PM
BlazingSaddle's Avatar
It's an inherent and often discussed problem with these bikes and the solutions seem to be like fingerprints; each one is different. It varies from steering head bearings, fall away adjustment, swing arms, tires, suspension. My last bike had it, my current bike does not. Traded it in and never found the cause.
I'm with the other guys on here, a damper is a band-aid fix, not a solution. A couple of guys in the forum have used the true-trak with good results, but I think that's for a whole different kind of wobble than what you're experiencing. The Original True-Track
Keep us posted if you find a fix.
BlazingSaddle is offline
post #9 of 11 (permalink) Old 11-11-2016, 07:23 AM
I agree with all of the above. A steering damper isn't needed and it is just a band aid. Your problem is either in the tires such as tire wear, cupping or inflation issues. The steering head bearing is a common problem and if the steering head bearing isn't adjusted correctly then the front end will get a wobble at speed.
My bike will go down the road with no front end wobble with my hands off the handlebars at all speeds, if the front end starts to wobble it is time to replace the front tire even though it doesn't look worn.
The only other thing you could do is keep the bike under 90 mph.
post #10 of 11 (permalink) Old 11-11-2016, 07:44 AM
Well that just wouldn't be any fun at all.
BG1960 likes this.
***2011 Steering Shake Issues*** smithdk130 Road Glide Specific Discussions 217 07-14-2015 09:21 AM
Steering Shake Survey by year 1BigGuy *General Road Glide Discussions/Pictures 43 01-29-2012 02:00 PM
2011 Road Glide steering head bearings bradj *General Road Glide Discussions/Pictures 5 02-12-2011 01:35 PM
2011 Road Glide steering head bearings bradj *General Road Glide Discussions/Pictures 0 02-11-2011 10:27 PM
Steering Damper for Road Glides Quick Aftermarket Accessories 13 01-27-2011 01:06 AM
