Cell phone mount - Road Glide Forums
 11Likes
post #1 of 40 (permalink) Old 01-07-2017, 11:23 AM Thread Starter
Cell phone mount
Switched my bars to 1.5 in. diameter and my cell phone mount won't work with these. Any suggestions on a mount to hold a Samsung s5. Larger size,approximately 3.5 in. x 6 in. with otter box case.
railer60 is offline
post #2 of 40 (permalink) Old 01-07-2017, 03:10 PM
stripclub's Avatar
I used a 1 1/2 roll cage mount with a ram mount X-grip phone mount and the short ram mount ball connector and it worked perfect holds the phone tight. In the pic I actually have my Power Vision in the Ram mount. All parts were purchased at Summit Racing.
stripclub is offline
post #3 of 40 (permalink) Old 01-07-2017, 07:00 PM Thread Starter
Thanks Stripclub but I didn't want anything in front of my boom screen.
railer60 is offline
post #4 of 40 (permalink) Old 01-07-2017, 09:33 PM
BH#103's Avatar
I use a Tech mount on my '15 which is awesome. I am in the winter mod project phase now and almost complete with the Factory 47 bars. One thing I forgot to consider was the bar mount for the Tech mount setup. I am next to positive they sell a 1 5" clamp which should remedy this small issue. Not sure if this helps, but since you mentioned cell phone mount, this is a possibility. If all else fails, talk with @seetiggergo about mounts, they can cover all your angles with their mount I'm sure. I picked one up for a Garmin I want to use but in the scenario I can't get a handlebar clamp to fit the phone, this will be my phone mount. Good luck, share your results!
BH#103 is offline
post #5 of 40 (permalink) Old 01-08-2017, 08:49 AM
SurlyBoy's Avatar
I used one of these ram mount tabs bolted through the mirror on the clutch perch. Use an x-grip for the phone.
SurlyBoy is offline
post #6 of 40 (permalink) Old 01-10-2017, 12:53 AM
i like the x mount
2016 CVO FLTRUSE ROAD GLIDE ULTRA- VANCE & HINES TRUE DUELS-V&H SLASH CUTS.-CB AND RADIO ANT. RELOCATION IN FAIRING-LIGHT ON TOUR PACK RACK-SO FAR
cvo shark is offline
post #7 of 40 (permalink) Old 01-10-2017, 06:51 AM
I use this for my S5...Can also use easily with mounts in truck and belt clip...case comes with magnet makes it easy to stick up just about anywhere...not cheap but I like mine.
https://www.rokform.com/pages/motorcycle-mounts
jimAZ likes this.
pappy66 is offline
post #8 of 40 (permalink) Old 01-10-2017, 08:53 AM Thread Starter
Thanks for the replies. Still looking
railer60 is offline
post #9 of 40 (permalink) Old 01-10-2017, 10:46 AM
Another vote for Tech mount, easy to install, reasonably priced, works great. They're coming out with a powered one soon to make it easier to charge your phone while it's there.
post #10 of 40 (permalink) Old 01-11-2017, 06:52 AM
*Jeffro*'s Avatar
Just installed an Iron Aces mount on my rgs. Real happy with the appearance. Super clean look.
*Jeffro* is offline
Custom Cell Phone Mount Alcyone92 Do-IT-Yourself 13 07-15-2018 07:24 PM
Cell Buckle - Cell Phone Mount FireGuy88 Aftermarket Accessories 39 07-21-2013 08:34 PM
Kuryakun tech connect fairing mount cell phone holder part 1697 Tomhppi Equipment-RG 1 03-30-2013 02:53 AM
Show me your Cell Phone/GPS Mount FireGuy88 Aftermarket Accessories 23 12-21-2012 07:32 PM
Cell phone numbers pte359 *General Road Glide Discussions/Pictures 8 11-17-2010 07:54 AM
