El Cheapo Tour Pack Setup - Road Glide Forums
 8Likes
post #1 of 28 (permalink) Old 02-25-2017, 01:27 PM Thread Starter
jcarruth's Avatar
I do not like tour packs, my opinion is that they ruin the lines of the bike. However, they are functional, especially for long trips. I wanted something that I could easily attach and remove, and not spend a lot of money on. As advised by others on this forum, this is the ticket! This is really nothing new, but I was so impressed with the results that I had to share. Total cost, $119.00
$55.00 for the tour pack and bolt on luggage rack, that goes on top, delivered from eBay. I am very impressed with the paint on this thing.
$60.00 for the quick detach luggage rack, delivered from eBay
$4.00 for 1/4" stainless bolts, washers and Nylock nuts at Lowes.
The first two pics show what you get. More pics to follow.
BARSR likes this.
2017 HD Road Glide Special
jcarruth is offline
post #2 of 28 (permalink) Old 02-25-2017, 01:30 PM Thread Starter
jcarruth's Avatar
El Cheapo Tour Pack Setup #2
More pics:
BARSR likes this.
jcarruth is offline
post #3 of 28 (permalink) Old 02-25-2017, 01:32 PM Thread Starter
jcarruth's Avatar
El Cheapo Tour Pack Setup #3
Last two pics:
BARSR likes this.
jcarruth is offline
post #4 of 28 (permalink) Old 02-25-2017, 01:45 PM
Looks damn good for the money. I'd run it on mine.
Sent from my LG-V700 using Tapatalk
wfowill is offline
post #5 of 28 (permalink) Old 02-26-2017, 11:31 AM
madmat's Avatar
Got any more info on how to get this?
scorpion6 likes this.
18 RGS Bonneville Salt Pearl
madmat is offline
post #6 of 28 (permalink) Old 02-27-2017, 11:59 AM Thread Starter
jcarruth's Avatar
Slight price increase.
Quick detach rack:
Detachable Two-up Tour Pak Pack Mount Luggage Rack For Harley Touring 2014-2017 | eBay
Tour pack with bolt on luggage rack:
Black Tour Trunk Pack For Harley Softail Dyna Electra Glide Road King Touring | eBay
You will need four 1 1/4" long 1/4" stainless steel bolts, nuts, and washers. Four fender washers included with Tour Pack. The other hardware is useless, except for the bolts that attach the luggage rack on top of the tour pack. For extra strength, I put steel straps between the fender washers on the inside of the tour pack, nuts and small washers on underside of the quick detach. Everything between plastic and metal is padded with old inner tubes.
jcarruth is offline
post #7 of 28 (permalink) Old 02-27-2017, 12:06 PM
I believe it fits but putting in the model of bike on the order sheet says this won't fit a Road Glide.
2016 ROAD GLIDE SPECIAL
evomind is offline
post #8 of 28 (permalink) Old 02-27-2017, 12:08 PM
evomind is offline
post #9 of 28 (permalink) Old 02-27-2017, 12:13 PM
One last question.....
Do you have to install the luggage rack? Im guessing it has pre-drilled holes for it so you pretty much have to.....
Id prefer a luggage rack-less look but not a deal breaker I guess.
evomind is offline
post #10 of 28 (permalink) Old 02-27-2017, 12:25 PM
IdahoHacker's Avatar
A few extra answers for y'all...
The tour pack comes with the luggage rack NOT installed: no holes drilled. So, if you don't like the luggage rack look, you're in luck!
I found the mounting hardware to be a very good assortment. It worked perfectly for me. The only change I made was to replace the four nuts with nyloc nuts.
The listing text makes it quite clear that this is a generic, "universal fit" item, that is NOT just for HD touring models. And that's why there is an "assortment" of mounting hardware, including top and bottom bracket-ey things to mount it to a generic luggage rack.
For a standard HD tour pack mounting plate, two of the four holes in the base are close enough that all I had to do was take a small round file and keyhole those two holes by 1/8" or so. For the other two holes I drilled new ones. A drill goes through the ABS like butter. Easy-peasy.
Bottom line for me: Just like the OP, I hate the tour pack look. Too big, too fat, hangs over the ass end of the bike, and too top heavy. One of the main reasons I liked this one is because it's a little smaller than a stock King tour pack. My intention was to buy this el-cheapo version, use it for Run For The Wall in May, and then toss it in the garbage when I got home. It looks so good, particularly the gloss black finish, that I'm going to leave it on.
For $58, it's mind-boggling.
moto.rich likes this.
2015 FLTRXS, SE Ventilator A/C, V&H Pro Pipe, S&S/Crane Chris Rivas Rocket 574 cams, Chris Rivas V-Twin dyno tune: 103 hp, 108 tq.
IdahoHacker is offline
WTB Cheapo touring trunk - non H-D Paul's Road Glide Wanted! (Buy or Trade) 8 05-27-2013 05:01 PM
Cheapo AC cover elbohead Intake and Exhaust 22 05-10-2013 02:07 AM
El Diablo apes for RG? RJRacey Controls & Handlebars 2 11-08-2012 02:20 PM
Riding to El Paso Tx this week Maxcustody *General Road Glide Discussions/Pictures 8 06-05-2012 09:33 PM
site of a shop in El paso tx Ditch Web Sites We Like! 3 08-10-2011 12:55 PM
