Aircleaner - Road Glide Forums
 4Likes
  • 1 Post By Tailbreaker
  • 1 Post By ironmark
  • 1 Post By skratch
post #1 of 7 (permalink) Old 05-05-2017, 10:25 AM Thread Starter
Aircleaner
Hi which aircleaner is the best if you have lower leg fairings i have oem stock aircleaner stage 1 on my 2015 fltrxs now,and has anybody tested some from china or is it crap.
ultra98 is offline
post #2 of 7 (permalink) Old 05-05-2017, 10:30 AM
Tailbreaker's Avatar
This is what I'm going with, although any stage 1 is going to perform about the same for most mods. And yes China stuff is junk!
ultra98 likes this.
Tailbreaker is offline
post #3 of 7 (permalink) Old 05-05-2017, 10:35 AM
Actually the stock HD high flow air filter provides all the air the bikes engine will ever need, any K&N style air filter will work just fine with any air filter cover you decide on. Basically it all in what you want for looks because one Hi Flow air filter will not outperform the other.
Tailbreaker likes this.
post #4 of 7 (permalink) Old 05-05-2017, 10:42 AM Thread Starter
Ok thanks,my thougts its beacause the air inlet is in front of my aircleaner and the lower legfairings maybe take some air away from inlet of the aircleaner.
ultra98 is offline
post #5 of 7 (permalink) Old 05-05-2017, 10:46 AM
I tried the Big Sucker style air cleaner with my lower fairings and I didn't like it but that's JMO. I put speakers in my lower fairings so the Big Sucker air filter wouldn't work so I just use the HD Hi Flow air filter with the cover of my choice and it works well.
ultra98 likes this.
post #6 of 7 (permalink) Old 05-05-2017, 11:00 AM
skratch's Avatar
it really is pretty much a question of looks. in the past, moving away from the stock ac would yield you a pretty good performance boost. now, not so much, the stock flows pretty good. until you start building up your motor, then all bets are off.
I started with the heavy breather with compact filter:
then I moved to the ventilator. I like it because it doesn't look like it's jammed up against the lowers.
ultra98 likes this.
skratch is offline
post #7 of 7 (permalink) Old 05-05-2017, 11:30 AM
Momania's Avatar
S&S Stealth.
Momania is offline
Screamin Eagle Ventilator performance aircleaner THEMASTERDESTROYER Sold 8 05-09-2015 12:51 AM
Can changing an aircleaner throw off a tune ? THEMASTERDESTROYER Intake and Exhaust 5 04-24-2015 01:53 PM
Harley Stage 1 CVO Aircleaner & K&N Easyryder01 Sold 14 07-06-2013 10:35 PM
Precision Billet aircleaner INSTALLED HUTMO Intake and Exhaust 14 03-14-2013 11:30 AM
WTB SE aircleaner Insert bvanlente Classifieds Archive (3 months old+) 2 08-04-2011 09:08 PM
