Brake line slack for 14" apes - Road Glide Forums
  • 1 Post By hazinthehides
post #1 of 6 (permalink) Old 05-10-2017, 10:18 AM Thread Starter
hazinthehides's Avatar
Wondering if anyone has installed a set of Factory47 14" apes on a 2017 Road Glide? I put a set of these on my '15 RGS without any issues, but I'm coming up short on the right side controls because there is not enough slack in the brake line. I've cut all of the tie wraps that I can see/feel. I don't want to remove the brake line and re-route it because I'll have to bleed the system and heard it may cause problems with the anti-lock module.
Thoughts?
Thx
hazinthehides is offline
post #2 of 6 (permalink) Old 05-10-2017, 05:34 PM
I just put those exact bars on my 17 RGU. If I recall correctly there was only zip tie around the tree holding both clutch and brake lines. The brake side was snug but there was enough. I don't remember doing anything special to get it to fit.
cheerio is offline
post #3 of 6 (permalink) Old 05-11-2017, 02:19 PM Thread Starter
Thanks cheerio! There was a hidden one that I had missed. Still tight like you mentioned, but had enough to mount it on the bar.
Swomack likes this.
post #4 of 6 (permalink) Old 05-11-2017, 02:38 PM
nsbohall's Avatar
Not trying to be a pessimist here, but why not spend a few extra dollars here and do it right? Would hate to see you have a problem down the road with lines that are stretched to their limit.
2013 FLTRU, S&S Power Tune Duals, Supertrapp Stouts, Andrews 48's, AN Big Sucker, Direct Link, Fuel Moto LED's, Custom Dynamics, 14.5 Madstad, 14" Carlini's, Legends AXEO and Revo A's.
nsbohall is offline
post #5 of 6 (permalink) Old 05-12-2017, 04:13 AM
Ln Vintage
Guest
Posts: n/a
What exactly do the brake lines cost? What is a good amount of reserve line I should have 3-5 inches???
post #6 of 6 (permalink) Old 05-17-2017, 09:57 PM
MisterUSA's Avatar
Check out Magnum Shielding. You can buy the section you need if doing it piece by piece vs. a full kit. Pretty reasonable $.
https://www.magnumshielding.com
MisterUSA is offline
Need slack in Clutch Cable and Brake Line bosshogg123 Controls & Handlebars 4 04-18-2016 08:59 AM
Best deal on cable/brake line kit for 16" apes? turbochrisb Controls & Handlebars 9 11-01-2015 12:39 PM
Clutch and Brake Line extensions for 14" apes ERod4116 Controls & Handlebars 10 08-09-2015 06:15 AM
14" Santee owners - your brake line routing? TitusPollo Controls & Handlebars 12 01-01-2013 09:23 PM
cable/brake line length for 18" apes SickRick Controls & Handlebars 6 09-04-2011 01:34 PM
