GADS Contact Info - Road Glide Forums
post #1 of 4 (permalink) Old 07-17-2017, 09:33 AM Thread Starter
GADS Contact Info
Hi all,
Anyone have a phone number for GADS? Bought deflectors for my 2015 RGS and no mounting hardware. WTF......goldie
goldie1951 is offline
post #2 of 4 (permalink) Old 07-17-2017, 01:34 PM
NickyNuts's Avatar
I had a problem with one side of my GADS and emailed the owner directly. he remedied the problem right away. The bolts that hold the GADS on, under the fairing are ordinary hardware store stock. (probably 1/4 - 20?) No excuse for missing hardware but if in a rush to mount them the bolts are available locally. A word of advice based on my experience on my 15 RGS, the factory threaded inserts that are used to mount the GADS may not be dead even with the bottom edge of the outer fairing. If you tighten the bolts too much you could crack the plastic around the mounting holes. To remedy the situation, if it exists on your bike, use flat washers on both sides of the mounting holes of the GAD. Also, the instructions says to torque the bolts to 20 ft/lbs, that seemed heavy to me on plastic so I torqued them to 10 ft/lbs with blue locktite.
NickyNuts is offline
post #3 of 4 (permalink) Old 07-31-2017, 10:51 PM Thread Starter
Thanks, found a phone number on my invoice and got my missing hardware and all is good......goldie
post #4 of 4 (permalink) Old 08-01-2017, 10:41 AM
Drifter -11's Avatar
Don't know if the newer bikes have a metal insert for the fairing screws or not.
If not and its plastic last time I used Locktite on a plastic application it ate away the plastic.
It was on turn signal covers those damn things just fell off leaving the screws in the housing.
Just FYI for you.
Drifter
2011 FLTRX - Totaled,
Cager
2013 FLTRU - Current
Patriot Guard Rider - Brazos Valley/Southeast Texas
Drifter -11 is offline
For those trying to contact Marty at GAUGELEDMODS TracyB Lighting 2 10-27-2012 09:48 PM
Avoiding rear tire / fender contact SmokinToad Suspensions 3 09-27-2012 03:31 PM
Contact info -AndyM GordonC Dyno Results 0 04-13-2012 06:11 PM
Larry Connell - Please Contact Me PC PaiN *General Road Glide Discussions/Pictures 2 12-15-2011 01:41 PM
