Love jugs vs fan assisted oil cooler - Road Glide Forums
 8Likes
post #1 of 16 (permalink) Old 10-20-2017, 02:40 PM Thread Starter
Got a 17 RG. I like the fan assisted oil cooler because you can't see it and it looks stock but fear it won't cool enough and I'll be better off with mighty mites. Any thoughts or opinions?
Lima14 is offline
post #2 of 16 (permalink) Old 10-20-2017, 08:21 PM
Thermodyne's Avatar
I'm guessing it's not a wet head, so Mighty Mites 24/7/365.
I run a set of black Wards jug fans on mine, they look about the same. And they are hardly noticeable. No one ever notices them untll they hear them cycle on.
It comes down to this. You can blow some air over the relatively small area of the oil cooler and its sub 300f surface temps. Usually 240f to 260f
Or you can blow air over the large area of the head fins and upper jug and its 280f and higher surface temps. Same air temp, but a lot more heat in the head.
RGKen and ALMOONEY like this.
Thermodyne is online now
post #3 of 16 (permalink) Old 10-20-2017, 09:11 PM Thread Starter
It's just oil passing through the heads. True enough though
Lima14 is offline
post #4 of 16 (permalink) Old 10-21-2017, 11:16 AM
Lu
Lu's Avatar
have you thought of installing both the fan assisted oil cooler and the CoolFlow fan that goes in the mid frame.
The fan assisted oil cooler will lower the temp of the oil before it goes through the heads and the CoolFlow is more for your comfort. I am planning to give this combo a try before installing a mighty mite or wards fan.
2011 FLTRU - Traded
2017 FLTRXS - Velocity Red Sunglo - Woooooo!!!
Lu is offline
post #5 of 16 (permalink) Old 10-21-2017, 03:37 PM Thread Starter
No I'm not so interested in keeping my legs cool, more just the bike. Anything I can do to help it whenever I get caught in traffic
Lima14 is offline
post #6 of 16 (permalink) Old 10-21-2017, 08:22 PM
The fan assist oil cooler has a thicker radiator than stock and that cool looking radiator cover that came out for the M8 will fit. The instructions claim it will not fit the FAOC but it will no problem.
RGSM8 is offline
post #7 of 16 (permalink) Old 10-22-2017, 11:52 AM
I'd suggest you install the Love Jugs first. You can then add the oil cooler if you think it's necessary (you probably won't) later. Also you have 30 days to return your Love Jugs for a full refund if you don't like them for any reason. Love Jugs are being called the Golden Bullet because they keep your oil 50˚ cooler and the cylinders 140˚ cooler in slow riding conditions when the heat really builds up. Steve
Thermodyne and moto.rich like this.
Steve West is offline
post #8 of 16 (permalink) Old 10-22-2017, 12:19 PM
Love Jugs no risk solution.
You might want to try the Love Jugs first. Chances are you will not need other help in cooling your engine and your oil (see love-jugs.com for AMSOIL test results). This suggestion is no risk to you because you can return your Love Jugs for a full refund if they don't meet or exceed your expectations. You can call me 24/7 to discuss at 561-499-0974 to discuss in detail.
Thermodyne likes this.
post #9 of 16 (permalink) Old 10-22-2017, 03:11 PM
moto.rich's Avatar
I’ve got the Love Jugs and they work great.
2016 RG, 103 HO.
OIF | OEF Combat Infantryman '05 | '07 | '09
moto.rich is offline
post #10 of 16 (permalink) Old 06-12-2018, 05:12 PM
till66's Avatar
Will it fit with lowers?
till66 is offline
Love Jugs v fan assist oil cooler sailronin Engine Related 14 09-11-2018 02:55 AM
jagg fan assisted oil cooler MRFLT63 Aftermarket Accessories 7 07-07-2012 03:39 PM
Jagg Fan Assisted Oil Cooler Review jimmyray11349 *General Road Glide Discussions/Pictures 8 03-29-2012 03:17 PM
Jagg Oil Cooler Fan Assisted jimmyray11349 *General Road Glide Discussions/Pictures 10 02-21-2012 02:12 PM
Jagg Fan Assisted Oil Cooler tj316 *General Road Glide Discussions/Pictures 6 06-25-2011 07:30 AM
