Transferring King TourPak from ‘08 to ‘18 - Road Glide Forums
 4Likes
  • 1 Post By calgaryglide
  • 1 Post By Stoic Joker
  • 1 Post By Willy_B
  • 1 Post By UT_Larry
post #1 of 7 (permalink) Old 11-22-2017, 12:57 PM Thread Starter
Bull_Duck's Avatar
Ready to buy a 2018 FLTR Special, and sell my 2008 FLTR Anniversary.
The 2008 is set up with a solo King Tour Pak. The Tour Pak is located where the passenger seat would normally be located.
I want the same setup for my new 2018. My ‘08 setup:
I know I will need a new quick release mechanism for the 2018. However, for my purposes, is there any problem other than color reusing the king box from my ‘08 ?
Bull_Duck is offline
post #2 of 7 (permalink) Old 11-22-2017, 01:34 PM
calgaryglide's Avatar
INterference!!!
The shape of the older tourpaks does not lend well to the opening of the saddlebags on the 18my.
You may have to raise your tourpak in order to clearance the opening of the saddle bags.
Newer Rushmore tourpaks are shaped differently at the bottom and taper inwards much more than the pre Rushmore tourpaks.
Calgaryglide
Bull_Duck likes this.
calgaryglide is online now
post #3 of 7 (permalink) Old 11-22-2017, 01:45 PM
Stoic Joker's Avatar
Calgaryglide
Interesting, when I took the TP off my 81 and put it on my 10 the bags opened just fine. Could it be a random issue with certain years/mount heights perhaps?? 81 TP was just bolted flat to a quick release mount/cargo rack.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #4 of 7 (permalink) Old 11-22-2017, 01:54 PM
Willy_B's Avatar
You will need to space the tour pak up 1/4-1/2” on the new base. With the way the new bags open from 14 and up they will not clear the pak. My buddy switched his 10 to newer style bags and lids and they wouldn’t open until he raised the tour pak up.
Willy_B is offline
post #5 of 7 (permalink) Old 11-22-2017, 02:15 PM Thread Starter
Bull_Duck's Avatar
You all have given me helpful comments. So I need to purchase a new base, new quick releases, and 1/2” bushings to get my ‘08 TourPak to work on an ‘18 FLTR. Oh ya, gotta have it painted as well.
All that is doable; certainly way less $$ than purchasing a dedicated ‘18.
Any anticipated problems with the above?
post #6 of 7 (permalink) Old 11-22-2017, 03:26 PM
Personally I'd just use a block of treated wood (like a piece of fence board) and paint it black. It's cheap, light, and would give full support to the TP.
post #7 of 7 (permalink) Old 11-22-2017, 04:02 PM
UT_Larry's Avatar
You may not need to increase the clearance. From reading other threads not everyone has needed to & your the first I’ve read about in the solo location. If you do need to raise it I recommend you use flat bar stock not bushings so the weight is transferred over a larger area.
UT_Larry is offline
2013 H-D Road Glide Gets A Custom 2014 King Tourpak Install skymech9 Lighting 1 03-15-2016 08:49 AM
King tourpak with SG backrest pad sedonaRG Parts for Sale 11 03-26-2015 10:13 PM
Lighting for King Tourpak on RGC, presently no lights on it mmfinn Lighting 27 07-05-2013 07:20 PM
Transferring Harley Warranty gfyoung3 *General Road Glide Discussions/Pictures 9 02-08-2013 07:07 AM
WTT Black Pearl Tourpak for Vivid Black Tourpak letsgofast Wanted! (Buy or Trade) 1 08-03-2012 01:54 PM
