Help with Dakota Digital MCL-3006 - Road Glide Forums
 2Likes
  • 1 Post By Wickedgmc
  • 1 Post By glide69
post #1 of 5 (permalink) Old 02-18-2018, 06:52 PM Thread Starter
Mike U's Avatar
I just installed a set of Dakota Digital MCL-3006 in Red on my 2012 Roadglide Custom.
I haven't completed the update of the gauges do to time constraints so I will take pictures tomorrow when I get back to the bike.
I have a question for those that have done the install already.
Is it necessary to install the new ground wire from the fuel gauge to the sending unit?
Also, is it necessary to install the Oil Temperature Sending Unit if I already have the Harley OEM one?
I've Googled the hell out of this to no avail.
Thanks in advance for any assistance.
MIke U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #2 of 5 (permalink) Old 02-18-2018, 09:51 PM
Wickedgmc's Avatar
My bike is an 04 and when I installed mine I did install the new oil pressure unit, DD recommended it and that was enough for me. I tried using the factory ground wire for the fuel sending unit and my gauge stays pegged at full. I have not had the tank or the fairing off since then to add the wire where they say to if the factory one does not work so I keep track of my mileage for fuel consumption.
So if I were to do it again I would just do both of them at the same time and be done with it. I also went with the MVX-8K Series, Analog/Digital Plug-in Instrumentation but it should not matter which set.
Mike U likes this.
2004 Road Glide FLTRI
Wickedgmc is offline
post #3 of 5 (permalink) Old 02-18-2018, 09:55 PM
Wickedgmc's Avatar
The Dakota system will give you oil temperature and the factory unit is not capable of that.
post #4 of 5 (permalink) Old 02-18-2018, 11:23 PM
glide69's Avatar
I had these on my 12 also.. All this info was in the installation instructions.. As II recall you don't need the ground wire for the fuel gauge.. You do need to install the temp sending unit.. The OEM is oil press not temp.. Easy install remove a plug from the pan and screw in. You can also program in your actual odometer reading this must be done in the first 100 mi I believe after that it's to late.. Good luck
Mike U likes this.
2018 FLTRXS Wicked Red
glide69 is offline
post #5 of 5 (permalink) Old 02-19-2018, 01:49 AM Thread Starter
Mike U's Avatar
I have the have OEM Harley Oil Temperature Gauge that I installed a few years ago.
When I did it I had to install the sending unit in the oil pan as described in the Dakota Digital instructions.
I was hoping the sending units are the same.
I guess if it works I'll be fine if not I'll install the new sending unit.
Thanks to all that replied.
That's why I always say this is "The Greatest Forum on The Internet!"
Mike U.
USMC 1975-1977
Semper Fi!
Mike U is offline
Dakota Digital MCL-3006-R 2004 - 2013 Fairing Models UltraNutZ Parts for Sale 2 02-25-2015 07:26 AM
Dakota Digital Gauges PC PaiN *General Road Glide Discussions/Pictures 42 11-17-2013 09:28 AM
Help: Dakota Digital gauges on 09 FLTR larrymz3 Equipment-RG 8 07-22-2013 05:02 AM
Dakota Digital METIME Controls & Handlebars 11 11-28-2010 03:55 PM
