Malcam TPMS - Road Glide Forums
 5Likes
post #1 of 19 (permalink) Old 02-19-2018, 11:23 AM Thread Starter
Morningwood's Avatar
Malcam TPMS
Anyone ever use this system. I was going to go with the FOBO system. I like that this has its own constant display (re-chargeable). It has good reviews the only downside is you cant set individual tire alarms, but I figure with the display always on that wouldn't really be a problem. I will get something after I get new tires and change to metal valve stems, was thinking this looked pretty good.
Morningwood is offline
post #2 of 19 (permalink) Old 02-19-2018, 02:55 PM
30glock's Avatar
Where is the display? and how do you see it while moving? I have the Fobo and I don't need the display, if there is any variance in tire pressure I get a loud alarm through the Boom system.
30glock is offline
post #3 of 19 (permalink) Old 02-19-2018, 10:09 PM
Are you running the FOBO system with rubber or metal stems?
bash103 is offline
post #4 of 19 (permalink) Old 02-20-2018, 06:00 AM
30glock's Avatar
My CVO has metal stems, when i first got the fobo system it almost killed me, I installed them on my 14 FLHTK with the rubber stem, started loosing air going 75 mph, almost completely sheering off the rubber stem.
30glock is offline
post #5 of 19 (permalink) Old 02-20-2018, 06:51 AM
snarley53's Avatar
what caused it to almost shear off the stems, the centrifugal force of the pressure cap on the rubber stems?
2011 roadglide ultra.2000 93" s&s rigid panhead,
40 ford rat rod pickup
snarley53 is offline
post #6 of 19 (permalink) Old 02-20-2018, 06:55 AM
I also have the fobo TPMS system, and basically, yes thatís what can happen. I have had this system on my last two RG, and am happy with it. I purchased FOBOs ďTĒ valves so I can add air without removing the unit.
FLTRXS18 is offline
post #7 of 19 (permalink) Old 02-20-2018, 07:11 AM Thread Starter
It has a LCD display that can attach to the bars. The display is rechargeable. The FOBO system looks great I just like having the pressures always visible. In my truck I always have the display set to tire pressures, just a glitch I must have. I will use my phone for GPS, I don't even try using the Harley GPS.
post #8 of 19 (permalink) Old 02-20-2018, 04:23 PM
30glock's Avatar
Had to be a combination of both, this topic is covered extensively at the other forum with most experiencing the same issue with rubber stems.
30glock is offline
post #9 of 19 (permalink) Old 02-20-2018, 07:46 PM
Malcam TPMS
Thanks. They recommend using metal stems. Just wondering if I should factor in cost to get the new stems installed.
bash103 is offline
post #10 of 19 (permalink) Old 02-20-2018, 07:54 PM
I have FOBO also, I didnít even think about using rubber stems because of the information I read from others. The metal stems were only a few dollars, nothing major.
Mike U and bash103 like this.
CVO TPMS on a special... RFG7680 Tech Area 46 08-29-2019 02:16 PM
FOBO TPMS T-valve Pictures tsmartt Wheels and Tires 19 01-17-2018 06:29 AM
Tpms ia15rgs Do-IT-Yourself 16 06-02-2017 01:57 PM
