Arlen Ness Deep Cut Shifter Rod - Road Glide Forums
post #1 of 3 (permalink) Old 04-01-2018, 02:57 PM Thread Starter
Hey everyone, looking for a little guidance on a oversight of mine!
So I purchased a Ness deep cut shift linkage (round) and when I went to install it I noticed the 2017 Roadglide has an offset from the back to the front. I was wondering if any of you out there have come across this as well and what your solution was?
I can't seem to find an "offset" inner shift rod to keep things in a perfect line or am I just reading into it a little to far?
Will this work at such an angle or will my shifting be hampered because of this? Looking for opinions before I remove it.
Thanks again and oh ya, it's -22C this morning in good old Alberta. Will summer ever come?😩
Livin the life is offline
post #2 of 3 (permalink) Old 04-01-2018, 04:08 PM
VDeuce's Avatar
Did yours come with hardware?
I was able to install mine (came without hardware) by using 2 1-1/4" 5/16-24 button head bolts (chrome), and had to use a spacer on the front to handle the offset. I could not find a suitable spacer, so I used 3 5/16 stainless lock washers and when installed, it is in perfect alignment. I used a 5/16-24 serrated nut on the back side.
Note that the front must go behind the shift lever. The 3 washers are used to space the linkage away from the lever.
So for the front, install bolt through sift arm, then 3 washers, then through linkage, then the serrated nut. Loctite the bolt with blue.
VDeuce is offline
post #3 of 3 (permalink) Old 04-01-2018, 05:20 PM Thread Starter
Thanks for the insight. My shift rod did come with the hardware. I never thought to mount the front behind the shifter as the shift rod has a cut out on the back side. I guess if there is no chance of it being damaged or scarred by the movement because of the spacers you used then who is the wiser!
I managed to find a video on YouTube of a gentleman that built a very sweet 2017 RDG Special that has one installed on the front side with the Arlen Ness inner shift rod as well but the video moves a little fast at that point and it's difficult to see how he managed the instal.
Again, thanks for the picture and your wisdom.
Take care my friend🍻
Arlen Ness Deep Cut turn signals ThunderBueller Lighting 20 04-14-2015 01:12 AM
Arlen Ness Deep Cut Factory Style Turns Gadgetech Lighting 5 05-21-2013 01:00 PM
Arlen Ness Deep Cut Shifter Linkage (Never Installed) SIG556 Classifieds Archive (3 months old+) 1 08-18-2012 10:07 PM
Arlen Ness Deep Cut on PYO Monkey bars??? Defy Controls & Handlebars 4 03-18-2011 11:20 AM
