2017-2018 Dakota Digital Oil Gauge - Road Glide Forums
 2Likes
post #1 of 12 (permalink) Old 05-09-2018, 09:27 PM Thread Starter
Live2Ride's Avatar
I'm getting ready to do a complete service on my bike and was going to get my Dakota Oil Gauge hooked up. I see in the directions for the gauges it is showing to use the oil drain plug area (2) to install the sending unit. I was wondering if this is where others have installed it or if you have installed it in the hex area (3)?
2017 Denim Black Road Glide Special
Live2Ride is offline
post #2 of 12 (permalink) Old 05-09-2018, 09:29 PM
Mike U's Avatar
L2R, Although my Glide is a 2012 I have mine inserted in the #3 Hex Area.
If you put it in the #2 Oil Drain Plug you will be taking it out every time you change the oil.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #3 of 12 (permalink) Old 05-09-2018, 09:45 PM Thread Starter
Live2Ride's Avatar
Mike U.
I appreciate the response. I figured that very thing, I just wanted to be sure I wouldn't have any other issues. I just found it odd that in the service manual Harley says not to remove that hex for some reason.
Mike U likes this.
post #4 of 12 (permalink) Old 05-09-2018, 09:50 PM
Mike U's Avatar
You're welcome Bro!
The Hex Plug comes right out, even though the Harley Manual states to never remove it.
The sender unit will fit right in.
Mike U.
USMC 1975-1977
Semper Fi!
Mike U is offline
post #5 of 12 (permalink) Old 05-10-2018, 06:45 AM
M8 gets installed in oil drain plug.
If you want to install in the hex plug, you will have to do a custom job.
Hex plug install is for pre-M8s. Kit doesn't come with what you need to install in hex plug if you have an M8.
2017 Hard Candy Hot Rod Red Flake M8 FLTRXS Road Glide Special. Stage III with *lots* of other goodies.
msquad is offline
post #6 of 12 (permalink) Old 05-11-2018, 12:21 AM Thread Starter
Live2Ride's Avatar
The sending unit came with a smaller adapter. I guess when I change the oil I will pull both plugs and see. It looks to me that I can put the sending unit into the hex hole without the adapter. I may just cover my butt and give them a call tomorrow to save myself any headache. Hate to install into the hex hole and have it blow out or something.
post #7 of 12 (permalink) Old 05-11-2018, 04:08 AM
glide69's Avatar
Keep us posted because I will be installing mine by the end of the month.... As already mentioned I Know on my 12 it went in the hex hole. Haven't even looked at the directions for the 18 install yet....
2018 FLTRXS Wicked Red
glide69 is offline
post #8 of 12 (permalink) Old 05-11-2018, 06:39 AM
Right, the smaller adapter is for the engine oil drain plug for M8s. The other adapters will not fit in the hex hole. I already tried it. I have the these gauges installed already. Had to put the hex back and use the drain plug hole.
My problem was I didn't understand the directions or I would have never taken out the hex plug. But since I did, I know for a fact that it won't work unless you went down a custom route.
msquad is offline
post #9 of 12 (permalink) Old 05-11-2018, 07:08 AM
^^^^ Same with my 18, unless DD is now sending the proper adapter with the set up now, you will need to use the oil drain location.
Live2Ride likes this.
FLTRXS18 is offline
post #10 of 12 (permalink) Old 05-11-2018, 10:08 AM Thread Starter
Live2Ride's Avatar
I see. I've had the gauges installed about a week or so just been waiting to do the sensor when I change the oil. I will do as you did since that is the design. Thanks
Sent from my SM-G950U using Tapatalk
Dakota Digital - Oil Temp Install Speedie Aftermarket Accessories 2 03-27-2017 03:06 PM
Dakota Digital gauge set Grind Parts for Sale 14 12-18-2013 12:48 AM
Dakota Digital Gauges PC PaiN *General Road Glide Discussions/Pictures 42 11-17-2013 09:28 AM
Dakota Digital Gauge Cluster, great for a custom build! i_timmers Classifieds Archive (3 months old+) 0 07-19-2012 12:00 PM
Dakota Digital METIME Controls & Handlebars 11 11-28-2010 03:55 PM
