Apes for a 2018 special - Road Glide Forums
 2Likes
  • 1 Post By Nutt2336
post #1 of 7 (permalink) Old 09-06-2018, 05:29 AM Thread Starter
Im sure this topic has been out. I'm looking for some 1.5 14" apes for my 2018 RGS.
Any suggestions??
Thanks
CGURRO is offline
post #2 of 7 (permalink) Old 09-06-2018, 05:30 AM
I bought the 14" Mayhem apes from Demonscycle.com. They are only 1.25" though but came powdercoated semi-gloss black and shipped for free for $179. The stock clutch and brake hose will reach, but you will need the short extenders for your hand control wiring. The bars are even drilled for the center pin and the pins under the clamps.
Here is the link to them if you want to look:
https://www.demonscycle.com/mayhem-b...e-2016-up-5536
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #3 of 7 (permalink) Old 09-06-2018, 07:14 AM
Nutt2336's Avatar
Any suggestions??
Thanks
Speaking from experience as well as what many others have said, go with bigger bars than what you want. So in your case get 16" bars. If you want 1.5" bars I would recommend the Factory 47 bars. I personally have the 16" F47 Signature bars for my 18 RGS and ABSOLUTELY LOVE THEM! I was thinking about 14's and VERY GLAD I went a size higher. The F47 bars are extremely easy to install at home due to the 1.5" size.
RustyStolzz likes this.
I am my Brothers keeper.
Nutt2336 is offline
post #4 of 7 (permalink) Old 09-06-2018, 01:46 PM Thread Starter
Any suggestions??
Thanks
Did you have to extend anything (wires/lines)? There's video out there from Factory 47 showing a 16" bar installation using stock lines.......
CGURRO is offline
post #5 of 7 (permalink) Old 09-06-2018, 01:48 PM Thread Starter
I had some JSR 14" on my 2015 and use all the stock lines and wires. Are the 18s shorter?
CGURRO is offline
post #6 of 7 (permalink) Old 09-06-2018, 04:54 PM
I don't know if you could get away with 16s. You might be able to do it if you pulled the clutch line and front brake line out of the plastic retaining block on the right side of the frame, by the neck. You will still need the wiring extensions for your LHCM and RHCM. The throttle wire is plenty long enough.
My clutch hose and front brake hose worked just fine, but by the time I had the LHCM and RHCM wires through the bars, they only stuck out about 2"s and the plugs were about 4" away. Lol. I probably could have unclipped the wires from the plastic panel they were on but I didn't want to put any un-due stress on the plugs.
Harley Master Tech
post #7 of 7 (permalink) Old 09-07-2018, 05:46 AM
Nutt2336's Avatar
I was able to use all stock cables. Only had to buy the wire extensions from F47 which were $30. For the cables you have to reroute them by taking them out of the factory channels they sit in and letting them run straighter lines. The install took me 2 hours (give or take) and that is mostly because this is my first RG and I had no idea how to take anything apart so I was following the manual step by step.
jimmywood18 likes this.
Nutt2336 is offline
2018 Road Glide Special PEZRACER *General Road Glide Discussions/Pictures 113 10-23-2017 06:00 PM
2018 Roadglide Special & CVO Streetglide Swomack General Off-Topic Discussions 31 09-19-2017 07:37 AM
2018 RG Special Black cbudge *General Road Glide Discussions/Pictures 5 09-16-2017 09:50 PM
2018 Road Glide Special leroydj New Members Welcome Area 25 09-15-2017 10:42 AM
Traded for 2018 RG Special!! Golo12sg *General Road Glide Discussions/Pictures 36 09-13-2017 09:32 AM
