Looking for LED lighting options for inside of the bags/tour pack. - Page 4 - Road Glide Forums
 34Likes
post #31 of 36 (permalink) Old 10-31-2018, 01:15 PM
OldNerdGuy's Avatar
I put on the Harley Kit, forgot the part number, and I have no pictures.
I do have a few notes from the install...
1. You will be drilling holes in your tour pak.
2. The wiring harness they provide is not well thought out. There is no easy disconnect should you want to remove the tour pak. This is in contrast with the Bike Harness which is (mostly) a full disconnect behind the seat. I say mostly because some dipshit attached a Tour Pak connector to the tour pack mount with one of those slide off type mounts that never slide off, so the Tour Pak is, essentially, physically connected to the tour pak mount. Also, the disconnect between the battery harness and the tour pak harness is INSIDE. You have to remove a grommet to disconnect the Tour Pak now.
3. The lights are really hard to operate. The button is in the middle of the fixture, and difficult to press. I have one saddle bag that I cannot get the light to work unless I press it with a screwdriver blade.
4. The battery harness is barely long enough to reach the inside connection.
5. The Harley catalog sez this kit is only for two Touring Models (no mention of a Road Glide Ultra), but it works for any Rushmore Bike with a King Tour Pak. They are all the same on the back end of the bike.
I would call this a no-go if someone were to ask for a recommendation. If the lights were easier to turn on/off then it might be worth it, but right now, I have only two that I can turn on/off with my finger. And the one that does not work easy is on the saddlebag I use the most (throttle side).
koryu2u likes this.
OldNerdGuy is offline
post #32 of 36 (permalink) Old 03-31-2019, 08:55 AM
lonestar429's Avatar
I bought some small leds from o'rielly's then used gorilla tape to attach to bottom of tour pack one on each side mag switch inside tour pack. ill try and post some pics when I get off work.
lonestar429 is offline
post #33 of 36 (permalink) Old 11-27-2019, 12:37 AM
snarley53's Avatar
https://www.walmart.com/ip/Tap-Night...4aAqCYEALw_wcB
2020 Roadglide Special, .2000 93" s&s rigid panhead,
40 ford rat rod pickup
snarley53 is offline
post #34 of 36 (permalink) Old 11-27-2019, 02:31 AM
bag lights
I'm considering these, a little pricey, but seem nice.
www.reda-innovations.com
Reda cycle stick.
2011 FLTRU, TTS, Windvest, Carlini Flying Apes, Fullsac Pipe & Rinehart 4", 107", Dragos 580,Ohlins 2.5, Hawg Wired, Wards Fans.
2019 FLTRXS Stage 1, S & S MK 45's, Carlini Flying Apes, Ohlins 2.5,
hdnali is offline
post #35 of 36 (permalink) Old 11-27-2019, 09:16 AM
Rauzer's Avatar
Thats pretty slick. Pricey of course, but looks pretty well thought out.
2011 Road Glide Ultra
Rauzer is offline
post #36 of 36 (permalink) Old 11-27-2019, 10:38 AM
I have those installed on my 2016 RGU, they work very well.
2016 Cosmic Blue Pearl RGU
2002 883R Sportster
Kennyd is online now
Tour pack lighting 05Quadrasteer Lighting 0 04-07-2018 04:18 PM
Looking for 2014+ tour pack lock options hades02 Do-IT-Yourself 2 05-10-2016 07:13 PM
Tour Pack Lighting Help 100edition Equipment-RG 5 03-28-2014 02:40 PM
tour pack lighting??? egiles Lighting 4 03-23-2014 07:53 PM
Some "Other" Lighting Options BLKNCr6 Lighting 7 06-12-2011 07:09 PM
