Cycle Electronics CE84T-12 - Road Glide Forums
 2Likes
  • 1 Post By Brewiz
  • 1 Post By Thermodyne
post #1 of 4 (permalink) Old 10-06-2018, 05:10 PM Thread Starter
JacktheBagger's Avatar
well my second stator went out on the Kentucky trip a couple weeks ago , on our long stop at the gas station in the middle of nowhere , I smelled it .. Had no issues getting home , changed the primary oil and it was black as coal with only 4000 miles on it , and stunk pretty bad ..
It's not dead yet , but if you ever had one go , they can do like mine did and burn bad and last for sometime before dying , or just die suddenly .. Not gonna wait ..
So have heard good things about the Cycle Electrics 50 amp kit , they claim much better low rpm charging than HD , and is a few dollars more than the HD kit , which you have to build from the pieces ..
Anyone here using the CE kit ?/
2011 Ultra
JacktheBagger is online now
post #2 of 4 (permalink) Old 10-06-2018, 08:32 PM
Mike U's Avatar
Jack, I have a Cycle Electric Voltage Regulator and am very pleased with it.
I am thinking of going with the Cycle Electric Stator CE-8012 over the winter, just because.
I have heard nothing but great things about Cycle Electric so that's why I'm replacing my OEM Stator before I have a problem out in the middle of nowhere.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #3 of 4 (permalink) Old 10-10-2018, 05:46 AM
Brewiz's Avatar
I had one and the matching Regulator installed in mine when they did my motor. Doesn't skip a beat even at idle...
Mike U likes this.
Brewiz is online now
post #4 of 4 (permalink) Old 10-10-2018, 11:14 AM
Thermodyne's Avatar
When I was rebuilding my 11 last winter, I found the connector from the stator to the regulator had a burned up pin. Charging had been a little off for over a year. I went with CEI for the replacements. Charges better now than it ever did before.
For these 09 on baggers, CEI redesigned the pins where the stator connects to the regulator. That's the most common point of failure. Bit hard to get them plunged in, but prevents them from burning out. And they use a more sophisticated circuit in the regulator. The oem regulator just dumps excess current to ground, making the stator work hard all the time.
A note of caution, if you run a Jagg oil cooler, you might have an issue mounting the CEI regulator
Mike U likes this.
Thermodyne is offline
Electronics question ddm502001 *General Road Glide Discussions/Pictures 14 04-09-2014 06:16 AM
electronics pauld Audio 1 09-15-2013 12:38 PM
Sierra Electronics comes thru OldNerdGuy Companies We Can Recommended! 0 01-18-2013 08:09 AM
It is now 12:12 12-12-12!!! Garemlin General Off-Topic Discussions 10 12-12-2012 09:45 PM
How much weather/water can the electronics take? TDavis Aftermarket Accessories 16 12-25-2010 11:07 AM
