New exhaust - Road Glide Forums
 2Likes
post #1 of 12 (permalink) Old 11-12-2018, 08:31 PM Thread Starter
New exhaust
I have a 2009 cvo roadglide. I purchased some true duals from a 2016 roadglide but the o2 sensor holes are smaller than than my old ones. Do they make a adapter or do I need to get a 2016 o2 sensor plug?
Jimmy Gray is offline
post #2 of 12 (permalink) Old 11-12-2018, 08:33 PM
Little Wing's Avatar
gonna assume you are using a tuner???
'18 FLTRX • '04 BAR HOPPER • '94 FLSTCTHE BEST BIKE ...is the one you're on!!!
Little Wing is offline
post #3 of 12 (permalink) Old 11-12-2018, 08:50 PM
bucketlisthd's Avatar
The sensors on an 09 are larger and in a different location than later models. I had aftermarket headers on my 09. I don't know if they are hard to find now, or not.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #4 of 12 (permalink) Old 11-12-2018, 09:18 PM Thread Starter
Its Vance and Hines true duals that I got. Just dont know of I should drill and tap the hole for the o2 sensors I have or find some type of adaptor
Little Wing likes this.
post #5 of 12 (permalink) Old 11-13-2018, 03:31 AM
glide69's Avatar
I just put V&H Power Duels on my 18 and they came with adapters... So there available...
2018 FLTRXS Wicked Red
glide69 is offline
post #6 of 12 (permalink) Old 11-15-2018, 06:37 AM
MyGlide's Avatar
Adapters
They make adapters to fit the 12mm sensors into the 18mm bungs but I don't think you'll find an adapter that can put an 18mm sensor into a 12mm bung.
2018 KTM Super Duke R
MyGlide is offline
post #7 of 12 (permalink) Old 11-15-2018, 06:42 AM
Here you go:
https://www.denniskirk.com/feuling-m...d=228600803220
2018 Road Glide Special Wicked Red SVT BoneShaker Exhaust, RCX Tormentor Headers, FP3, Vance & Hines VO2 Naked Air Intake, AIMS Light Force Slave Cylinder, Legends REVO-A Shocks
aviscomi is offline
post #8 of 12 (permalink) Old 11-15-2018, 06:52 AM
MyGlide's Avatar
Originally Posted by aviscomi View Post
Those adapters allow you to install a 12mm sensor into an 18mm hole not vise versa.
MyGlide is offline
post #9 of 12 (permalink) Old 11-15-2018, 07:04 AM
These will...though I don't recommend them.
https://www.amazon.com/Innovate-Moto.../dp/B001QFL8LI
aviscomi is offline
post #10 of 12 (permalink) Old 11-15-2018, 07:15 AM
MyGlide's Avatar
Those would be absolutely useless. The sensor would not even be in the exhaust pipe.
To the OP, your best bet is to either find someone that can drill into your pipe and weld the 18mm bungs in place and plug the 12mm ones or simply find another pipe that already has the bigger bungs for your year model.
wevsspot likes this.
MyGlide is offline
Harley Exhaust RineHart Dual Exhaust 4" darinhebert Parts for Sale 0 06-13-2014 09:34 AM
Exhaust Leak- Re-installing Exhaust System tonight X In Black Intake and Exhaust 13 02-27-2013 03:21 PM
2 into 2 exhaust - new from HD carcass Intake and Exhaust 7 07-06-2010 10:56 PM
